Ruanne Cluer
I wanted to see your Mn, Mpb, n, Ma were balanced .. which they are You might want to add -PendConnTime 10 (the default is 30 seconds on SQL servers) We've got a code example on ReleaseObjectPool: -- the Close() method is used to disconnect from a connected database. -- with CP, OdbcConnection.ReleaseObjectPool() method should also be called to release the ODBC Driver Manager environment handle when the last underlying connection is released. Otherwise the connection to the database will be be held by the ODBC Driver Manager. 000067957 - .NET ODBC Connection not terminating immediately knowledgebase.progress.com/.../NET-ODBC-Connection-not-terminating-immediately
