Thierry Ciot
Chris, The default % allocated to the width of the label versus value container is defaulting to favoring longer value than labels. This can be tailored. Please try &demoFieldsLayout=true on edit page or on object view to see a border around labels and values fields. And you will immediately see where the space is allocated. Obviously, we cannot provide a default that would work for everyone. But there are several options for you: 1) You could try to set the section to use 4 columns - these will automatically be responsive and scale down to 2 columns when on smaller screen/device size and to 1 column on even smaller. -> goto page designer and set to 4 columns in section property. From what you are pointing in your screenshot, at least in first section, should help fill up the space. 2) You could try to use the setting "Show Label Above field Value on all devices" -> Got to live preview to set this and see its effect without affecting all your users. If you like it save it. 3) You can tailor the % of space allocated to the label versus the value using css override. In the future, we would like to provide a point and click mechanism for adjusting the %. Thierry.
