Please report any problems or bugs here with the upgrade so we can investigate.
Thanks!
Thanks!
I have to agree with Bendaluz2: Some of the colour schemes are difficult to read.Originally posted by bendaluz2
Dunno if id call it a problem really, but its a problem for me. I cant read the post header information because the text is black on dark blue
Are you talking about the dark blue strip above each post, where it has the date/time on the left and post title on the right? This should be white text, not black... but if it is black then that's a problem (I'd have trouble reading that too!).Originally posted by bendaluz2
What browser and version are you using at work and at home? It might be a problem with certain browsers...Originally posted by bendaluz2
Oooh, thats interesting. I'm at home now, and it is white text on dark blue
Originally posted by Crittar
Chris,
By no means a major problem but if you try to sort the members screen by reputation it doesn't seem to work. It seems to sort just by username if you try to sort by reputation.
Bendaluz,
If you hover your cursor over the little green button alongside the name in each post it gives a 'reputation status' - from that I know there are people out there with reputation, just that the sort doesn't seem to reflect this.
Ah, I thought that was just some cryptic thingy. I thought there would be different icons for differing reputation, so you could see easily. If there isn't, maybe there should be?
ie5 at work, and i'll let you know when I get home :awink:
Chris,
Actually the little green dots below your avatar next to the post count show your reputation. Right now it's a single dot for everyone, but you get more dots the more reputation you haveOriginally posted by Crittar
Could be a good idea but I suspect it would be difficult to manage - a halo over your avatar if you get a high enough reputation maybe? :awink:
Testing > and <Originally posted by bendaluz2
I have, on numerous occaisons, used < and > to do greater than and less than signs in my posts. These are no longer being translated and just appear as < and >
Testing < and >Originally posted by Chris Schreiber
Testing > and <
Looks like you need to use "& lt ;" and "& gt ;" without the spaces.... you are missing the ";" at the endOriginally posted by bendaluz2
