SQL from both OE and sqlexp
JustMe
Newbie, on progress day 4 continued ...
(Is this SQL or DB problem?, should it be moved to DB forum?)
The version is 10.2b 05
I am running eclipse on windows XP servicepack 3 (Admin programs also)
The database is running on SLES11 linux
After setting up a second broker for SQL only I can connect from both OE and sqlexp.
But when I send a query from either I get the error:
[DataDirect] [OpenEdge JDBC Driver] [OpenEdge] Table/View/Synonyum not found (7519)
the OE will let be "browse" the tables.
Any and all help appreciated ...
JustMe (Rich)
JustMe
it is very complex ...
SELECT tablename.field FROM tablename;
specifically (SELECT item.BAR-CODE FROM item ;)
Rob Fitzpatrick
Try qualifying the table references with the schema, e.g. PUB.tablename.field.
Also, enclose the table or field names in double quotes if they contain a hyphen. E.g. ... PUB.item."bar-code". Or ...PUB."table-name"...
abevoelker
Since you're using the JDBC driver, you can set the "defaultSchema" property to "PUB" before you connect, and you won't have to preface your table names with it.
