[progress Communities] [progress Openedge Abl] Forum Post: Re: When A Comment Contains An...
  • Thread starter Thread starter Santosh Patel
Santosh Patel
Thank you for reporting this bug. Happens in the new UI only. While this is fixed officially, here is a workaround that you can use: In file commentEdit.jsp ( /webapps/prod/m/commentEdit.jsp) look for a section with the following content and replace it with this i.e. replace the value's enclosing double-quotes with back-ticks. Do this for all occurrences of commentEdit.jsp (master and all prods) That should do the trick. Let me know if this works for you.
