[progress Communities] [progress Openedge Abl] Forum Post: Re: View Width?
  • Thread starter Thread starter Vimalkumar Selvaraj
V
Vimalkumar Selvaraj
Hi Greg, Are you using classic UI or NewUI?. We recently added support for this feature in NewUI. When you set view width for a field that honored while rendering list view grid in NewUI. If no width set column header width decided based on column label text. But you should be able to resize your column by using column re-sizer option. you see this option when you mouse over column separator line. Once you resize the column it get saved as user preferences. From then column uses resized width. All these features available only in NewUI. In Classic UI (OldUI) still view width has no effect. Thanks, Vimal.
