[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Test DB crash on Linux RH 7.2 while running OE 11.7.2
  • Thread starter Thread starter dvoyat
dvoyat
Thanks George and Cjbrandt for your reply.Just to add extra comment there was no error in var/log at all. I can for sure try to enable AI and see if I can get some detailled infos. I've also gone through various posts in community, included the one George kindly mentionned but was not finding anything obvious .... except the bug suspicion. We've done some earlier try with 11.7 with same server this spring. We've tried to run several test dbs and got something similar. At that time we stopped all db and restarted only one and turn to default semset to 2 (rather 3) it worked but had to move to some other project work and therefore stop/pause some more 11.7+ Linux testing I'm now restarting. I can also change both appserver and batch to connect via TCP socket and see if it goes better. I also let the default SEMOPM to 32 as I understood from some earlier post that this is not relevant to Progress (or at least was not).
