[progress Communities] [progress Openedge Abl] Forum Post: Re: Telerik Treeview Component
  • Thread starter Thread starter Ilya Kogan
I
Ilya Kogan
Thank you for your reply, The data coming in that is being populated into the datasource could is always different, so there is not a set amount of ids that come through. For example: It could be 1 or it could be 50. In order for the treeview to save the position/parent/children I believe I have to reset the fields using the setfield api and set it each time someone is drag and dropped(drag end). The nodes won't contain items, they will simply contain the nodes that have been dragged under itself. Does this make sense?
