[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: Release Build Issues
  • Thread starter Thread starter Radoslav Kirilov
Radoslav Kirilov
Hi Louis, The problem is caused by dependency injection and magnification of the code in release mode from the jtsNavigation.module.js file. You have : var resolveTemplate = ($q, jtslibService, $state) => { However the $q, jtslibService, $state are not injected in strict mode. So when the code for release is produced and it is minified and obfuscated the services names are replaced with shorter names. More info you can find here: Declaring AngularJS Modules For Minification To fix the problem you can add: resolveTemplate.$inject = ['$q', 'jtslibService', '$state']; Best, Rado
