smat-consulting
Depends on what you have in your ini file (or registry, if you're not using an ini file). I haven't worked with guy in a long while (doing only Web UI these days, to make app available to anybody, not just the MS users). What I do remember is, that you can define a bunch of fonts in the ini file, and then assign the font that you like to the editor-widget... The font's you define are similar to what you see in a font selection drop-down in a word processor Most obvious choice for fixed font is courier. But I think there are others...
