DenDuze
Hi Laura, Yes I understand that but I thought that when you sent an instance of a class to the server as input-output that that object would be send back to the client with everything that belongs to that object. So also all datasets/buffers/tt's that are created/changed on the server.... but it looks like that does not work.(because they are dynamically created) I changed it for now like Simon suggested, so with a static defined temp-table that holds a jsonObject instance with the content of the dataset taht is created on the server --> That works. The only problem I still have is the fact that I have some memory leaks (datasets and temp-tables that should be destroyed but are not) - have to test further how to be sure that everything is cleaned up correctly.
