[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: PAS instance (11.7) does not appear in the Explorer connection when creating a server o
The version = UNKNOWN thing is not good and normally means there is a problem. I would stop everything, delete the log files for your instance, turn up your agent logging levels and then restart. You should be able to find KB's for all these things. The PASOE instance logs are the most important place to go when PASOE is behaving unexpectedly. For every ABL app there is normally a "session manager" log file and an "agent" log file. Those are the ones to scrutinize. Are you hosting PASOE in windows or linux? On windows you should ensure that everything is running with a consistent account that has local admin. Eg. if you start admin server you will find it in task manager running as "local system". Then start your PASOE from OEE and it should also run as "local sytem". Another thing to try is just creating a fresh PASOE instance using the tcman command with different port numbers - then see if it works any better than the current one. Something might have gone amiss. The good news is that if you can get another fresh instance running successfully then you can probably look in the conf directory and compare the configuration of the old and new ones in the openedge.properties file.
