P
pknopfgfa
Hi, Im sure you'll get a plethora of answers for this. I'll share what I do though it's not an exact answer to your question... I share it as if you find a scanner app that uses the camera, you should be able to use that like I use the scanner in my example or you can attach a scanner to your phone, that should work as well. What I do has little to do with KUIB. I attach a bluetooth barcode scanner to my PC, which is a Mac in my case. I ensure my scanner can read the type of barcode I need. Then when I enter a field with the data type that equals my barcode, instead of typing the value in via the keyboard, I scan the barcode and it populates the KUIB filed with no issue.
