[progress Communities] [progress Openedge Abl] Forum Post: Re: Creating Mobile Card For...
  • Thread starter Thread starter Thierry Ciot
Thierry Ciot
There is a bug here. The popup is supposed to show a couple of data from the event or task and just below 2 buttons to either view or edit the object. The bug is that these 2 buttons get removed dynamically after the popup is rendered. Same bug is affecting event/task create. This bug is affecting calendar only when rendering on mobile. Now back to your question: card support is for controlling how list items are rendered in card view (as opposed to list view). So it does not apply in this case. The way you control how event/task view or event/task edit is by leveraging the responsive and adaptive features for object view and object edit. In other words, you can control how this is rendered by using "Design this page" for object view or object edit. Thierry.
