[Progress News] [Progress OpenEdge ABL] How Progress Data Platform Turns Fragmented Manufacturing Data into Connected Intelligence
H
Hinal Patel
In the first part of this series, we looked at a problem familiar to manufacturers: critical information exists across the organization, but the context needed to make a decision often does not travel with it.
Why? Because engineering has the design, manufacturing has the production plan and procurement owns supplier and cost information. Meanwhile, quality has inspection and nonconformance records, and operations has real-time production data. Service has yet another view: how the product performs once it leaves the factory.
The challenge is connecting those these disconnected views without asking the business to replace its business-critical systems.
Progress Data Platform is designed to create a governed manufacturing intelligence layer across existing systems, connecting plant, product, quality, supplier, service and compliance information, so teams can use that information in operational workflows, analytics and AI.
PDP isn’t about creating another isolated destination for manufacturing data. Rather, it’s about making the relationships within that data easier to understand and use.
Connect the Systems that Already Run Manufacturing​
Manufacturing environments are inherently heterogeneous:
  • Enterprise Resource Planning (ERP) may hold orders, inventory and financial information
  • Product Lifecycle Management (PLM) manages product structures, specifications and revisions
  • Manufacturing Execution System (MES) captures production activity
  • Quality Management System (QMS) manages defects and corrective actions
  • Supplier systems hold parts, certificates and risk information
  • Important knowledge also lives in manuals, drawings, specifications, work instructions and other documents
Replacing all of these systems to create a connected view is rarely practical.
Progress Data Platform brings information from disconnected environments together while preserving the context and identifiers that matter to the business. The result is a foundation that can connect structured and unstructured information across products, parts, suppliers and operations without requiring a wholesale rip-and-replace of the systems of record.
That creates a different starting point for manufacturing intelligence.
Instead of asking each system for one piece of the answer and manually assembling the result, teams can work with a connected view of the information needed for decision-making.
Understand How Products, Parts, Suppliers and Processes Relate​
Connecting data physically is only part of the challenge.
Manufacturing organizations frequently have different identifiers, terminology and data models for the same real-world object. A part may have one identifier internally, another from a supplier, and different representations across plants or acquired businesses.
Progress Data Platform helps organizations add business meaning and relationships to that information.
Semantic technologies, knowledge graphs and ontology management can provide the underlying foundation, but their business value is much simpler: they help the organization understand how products, parts, suppliers, engineering designs, manufacturing processes and operational assets are connected. The ABM strategy identifies this connected context to support engineering-change impact analysis, EBOM and MBOM reconciliation, component traceability, supplier-risk analysis and AI initiatives.
That connected context can be applied to several high-value manufacturing priorities.
Improve Design-to-Cost Decisions​
Design-to-cost can be difficult when engineering decisions are separated from supplier options, manufacturing requirements, inventory and historical cost information.
Progress Data Platform can bring those sources into a connected product context, helping teams compare parts and suppliers, understand where components are already used, evaluate alternatives and see potential downstream implications earlier in the design process.
Instead of treating engineering cost analysis as a series of manual reconciliations, organizations can build a reusable view of products, parts, suppliers and cost information across sites.
That can help engineering and procurement teams make more informed decisions before cost becomes locked into the product.
Strengthen Product and Component Traceability​
Traceability is most valuable when something goes wrong: a supplier reports a suspect lot, a quality issue is discovered or a customer claim comes in.
Teams suddenly need to know which parts, product configurations, production batches, suppliers and (possibly) customers are affected.
The ABM brief identifies this as a core manufacturing challenge: disconnected component, material and product information can increase recall risk and slow corrective action.
Progress Data Platform can connect supplier, material, lot, product, quality and compliance information so teams can follow those relationships across systems. Doing so can accelerate root cause investigations, make it easier to identify potential business impact, helping teams assemble supporting evidence and take action.
Create a Stronger Digital Thread​
An engineering change has consequences beyond the engineering organization. It can influence a bill of materials, supplier requirement, production process, work instruction, inspection criterion or service procedure, as well.
Yet EBOM, MBOM, testing, procurement and supplier information often operate independently, resulting in slower change management and limited cross-functional visibility.
Progress Data Platform helps connect those lifecycle relationships so product context travels across engineering, manufacturing, quality, suppliers and service.
For teams investigating a field issue, that could mean tracing the issue back through a specific engineering change, supplier lot, production event and work instruction. For teams evaluating a proposed change, it could mean understanding more of the downstream impact before it is released.
The digital thread is usable product intelligence that keeps the manufacturing lifecycle running smoothly.
Give AI the Context Needed to Produce More Useful Answers​
Connected manufacturing intelligence also creates a stronger foundation for AI.
An AI system helping investigate a quality problem should not reason from an inspection result alone. It may need the specification that applied at the time, the supplier lot, process parameters, engineering history, prior nonconformances and approved corrective-action procedures.
A system helping an engineer evaluate a component should understand the product configuration, manufacturing requirements, previous use, supplier options and cost context.
Progress Data Platform can ground AI workflows in connected manufacturing information while supporting controls around evidence, permissions, policies, approvals and traceability. The manufacturing GTM strategy specifically positions those capabilities around trusted decisions, product protection, operational optimization and supply-chain resilience.
The result an AI-enabled workflow in which the answer can be connected to the information the business needs to evaluate and act on it.
Fix One Problem, Measure It and Move on​
A connected manufacturing intelligence strategy does not need to begin as an enterprise-wide transformation.
In fact, the recommended approach is to pick one workflow, one business outcome and one measurable starting point, and go from there.
Examples include:
  • Reducing the time required to assess an engineering change
  • Improving the speed of suspect-lot containment
  • Reducing manual effort in root-cause analysis
  • Giving engineering teams better visibility into cost and alternative parts
Progress’ manufacturing GTM approach recommends starting with a focused workflow, mapping the required sources and evidence, defining governance requirements and measuring value before expanding to additional plants, products or use cases.
That is ultimately the role of Progress Data Platform in manufacturing. It does not replace the systems that run the business; it connects the context across them, so data becomes more useful and decisions easier to defend. Most importantly, AI has a stronger foundation on which to operate.
When products, parts, suppliers, processes and operational information can be understood together, manufacturers can do more than collect data. They can put it to work.
See how Progress Data Platform can connect manufacturing data across engineering, operations, quality and supply chain.
