marian.edu
Hi Pierre, we do use extensively Bootstrap along with Angular and sometime Kendo, how do you get data from back-end is not that important as far as the UI is concerned… it’s all JSON so any REST will work just fine. We use our own akera.io as ‘application server’ but webspeed can work as well, depending on the OE version there can be more or less support for JSON so it’s rather nice to be on a more recent version if you go that route. If you’re interested to find out more we do offer consulting services in area of web/mobile development for OE applications, you might also want to check out our sports2000 demo - http://sports.akera.io:8080 Best regards, Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
