Mike Fechner
My guess is that the iniFile Parameter is wrong – or the variable is not set. I’ve had similar unfriendly ways of telling me that also with the assemblies parameter. Just ${prop.iniFile} prior to the PCTCompile invocation to verify. Or run ANT with -v for verbose output. Von: MBeynon [mailto:bounce-MBeynon@community.progress.com] Gesendet: Dienstag, 9. Januar 2018 09:33 An: TU.OE.General@community.progress.com Betreff: [Technical Users - OE General] Bamboo and PCT ANT Update from Progress Community MBeynon Hi, I'm trying to configure a build for my project using our Bamboo server and a PCT ANT build script and I wondered if anyone on the forum has tried this? I did a search before writing this post but to no avail. I can get my script to run on Bamboo but it breaks as soon as it hits the first compile statement that makes reference to my assemblies or ini file I get an error. My ANT script uses a properties file. Here are two of the items in it; assemblies=build\\assemblies iniFile=build\\Compile.ini And here is a part of my script that is failing; .......... The error I get is; BUILD FAILED C:\BambooBuilds\PETL-PETL-JOB1\build\build.xml:120: java.lang.NullPointerException at com.phenix.pct.GenericExecuteOptions.setIniFile(GenericExecuteOptions.java:181) at com.phenix.pct.CompilationWrapper.setIniFile(CompilationWrapper.java:351) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) The Bamboo build folder structure is; Bamboo BUILD FOLDER -->build folder -->assemblies folder -->assemblies.xml -->Compile.ini I've got the script working and building a library on my local PC but I'm really struggling with the Bamboo side of things. I'm sure it must be something quite simple that I've missed but I can't see the wood for the trees at the moment
Thanks, Mark. View online You received this notification because you subscribed to the forum. To stop receiving updates from only this thread, go here . Flag this post as spam/abuse.
