[progress Communities] [progress Openedge Abl] Forum Post: Output Stream Is Not Working...
  • Thread starter Thread starter Joseph Kreifels
Joseph Kreifels
I assume there must be a bug in my work environment this is the strangest thing. My co worker is able to get things to work fine, so this is an isolated issue with my development environment. Version: 10.2B OS: RHEL The output stream fails to output all the data. I can get it to do so by using the "unbuffered" option however. There are two examples here. 1. It will not output less than 1024 characters. 2. If more than 1024, it will only output everything that can be evenly divisible by 1024. Example: If I need to output 12,989 characters of data to a file, the file will only get 12,288 It's a very strange problem indeed, and the fact the output is working with the number 1024 makes it all the more strange. Incase you're wondering what methods i'm using here is a short example: def var file-ou as char no-undo init "/u/tmp/outstream.csv". def stream s-out. output stream s-out to value(file-ou). put stream s-out unformatted fill("0",1024) skip. output close.
