[progress Communities] [progress Openedge Abl] Forum Post: Error Found On First Start...
  • Thread starter Thread starter tawatchai
tawatchai
I did fresh install V. 4.0.5.2 into my window 7 with Thai Regional Setting. Installation process is perfect completed without any error. But, when I do first start up Rollbase Application server using startup.bat in DOS box. There are some error message about invalid date . This error was found since V. 4.0.4, I don't know what enhancement made and impact on this. The new version recognize Thai Regional Setting in my windows setting and it use Thai year in its initialize process. And further more , it also impact to data in sample application in rollbase such as CRM , .... The created date and update date of those record store in DB were in year 2559. not 2016. Below here is message ==>> MASTER Server is starting ROLLBASE_HOME=C:\Progress\Rollbase\Pas_Instance\rollbase Config file to insert : databases.xml Config file to insert : components.xml Config file to insert : serviceLevel.xml Config file to insert : shared.properties Config file to insert : events.xml Config file to insert : license.xml Config file to insert : listItems.xml Config file to insert : fieldGroups.xml Requesting file from database shared.properties Requesting file from database license.xml Host name: localhost:8830 Requesting file from database components.xml Requesting file from database serviceLevel.xml ==>> Installing local Progress Rollbase instance Creating Master Zone: system records Start installation at: Thu Feb 04 19:02:28 ICT 2016 Requested file listItems.xml Creating Master Zone: installing app1_rb.xml Lock status: Unlocked ===>> Installing application: Rollbase [v. 1] Requesting file from database events.xml Creating Master Zone: installing app2_org.xml Lock status: Unlocked ===>> Installing application: Organization Management [v. 1] Creating Master Zone: installing app3_sys.xml Lock status: Unlocked ===>> Installing application: System Console [v. 1] Creating Master Zone: installing app4_mkp.xml Lock status: Partially Locked ===>> Installing application: Marketplace [v. 1] Creating Master Zone: installing app5_isv.xml Lock status: Unlocked ===>> Installing application: ISV Partner [v. 1] Creating Master Zone: installing app6_supp.xml Lock status: Unlocked ===>> Installing application: Support Center [v. 1] Creating Master Zone: installing app7_appr.xml Lock status: Unlocked ===>> Installing application: Approvals [v. 1] Creating Master Zone: installing app8_crm.xml Lock status: Unlocked ===>> Installing application: CRM [v. 1] Creating Master Zone: installing Sample Apps Publishing application: CRM Publishing application: Approvals Publishing application: Organization Management Publishing application: Rollbase Creating Master Zone: admin account for micloud.th@gmail.com ===>>> Send emergency email: Installing Private Cloud for micloud.th@gmail.com Installing Private Cloud for micloud.th@gmail.com Host: smtp.gmail.com User:micloud.th@gmail.com Copyright ยฉ 1993-2015 Progress Software Corporation. All rights reserved. Rollback transaction #23 in thread 13 due to java.lang.IllegalArgumentException: 2559 is not a valid year java.lang.IllegalArgumentException: 2559 is not a valid year at com.rb.util.core.DateUtil.validateDate(DateUtil.java:693) at com.rb.util.core.a644.parseShort(a644.java:121) at com.rb.util.core.a644.parseLong(a644.java:138) at com.rb.util.core.DateUtil.parseLong(DateUtil.java:662) at p15.a367.mark(a367.java:83) at p15.a367.mark(a367.java:48) at com.rb.core.data.common.Customer.doUnload(Customer.java:883) at com.rb.core.data.common.Customer.doUnload(Customer.java:874) at p24.a59.checkInstallation(a59.java:125) at com.rb.master.logics.servlet.Starter.init(Starter.java:79) at org.apache.catalina.core.StandardWrapper.initServlet(StandardWrapper. java:1280) at org.apache.catalina.core.StandardWrapper.loadServlet(StandardWrapper. java:1193) at org.apache.catalina.core.StandardWrapper.load(StandardWrapper.java:10 88) at org.apache.catalina.core.StandardContext.loadOnStartup(StandardContex t.java:5176) at org.apache.catalina.core.StandardContext.startInternal(StandardContex t.java:5460) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:150) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase .java:901) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:87 7) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:633) at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:976) at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java: 1653) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:47 1) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor. java:1110) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor .java:603) at java.lang.Thread.run(Thread.java:722) Email message "Welcome to Progress Rollbase" to micloud.th@gmail.com Progress Rollbase (ID=1) "Welcome to Progress Rollbase" to micloud.th@gmail.com Release: 4.0.5.2 Master Server MASTER: Initialization completed successfully เธ .เธ . 04, 2559 7:03:45 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployWAR INFO: Deploying web application archive C:\Progress\Rollbase\Pas_Instance\webapp s\prod1.war ==>> PROD1 Server is starting Production Server PROD1: Initialization completed successfully เธ .เธ . 04, 2559 7:04:24 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployWAR INFO: Deploying web application archive C:\Progress\Rollbase\Pas_Instance\webapp s\rest.war ==>> REST server is starting เธ .เธ . 04, 2559 7:04:25 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployWAR INFO: Deploying web application archive C:\Progress\Rollbase\Pas_Instance\webapp s\router.war ==>> ROUTER server is starting เธ .เธ . 04, 2559 7:04:25 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployWAR INFO: Deploying web application archive C:\Progress\Rollbase\Pas_Instance\webapp s\search.war ==>> SEARCH Server is starting เธ .เธ . 04, 2559 7:04:27 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployWAR INFO: Deploying web application archive C:\Progress\Rollbase\Pas_Instance\webapp s\storage.war ==>> STORAGE Server is starting เธ .เธ . 04, 2559 7:04:35 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployWAR INFO: Deploying web application archive C:\Progress\Rollbase\Pas_Instance\webapp s\webapi.war ==>> WEBAPI Server is starting เธ .เธ . 04, 2559 7:04:35 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployWAR INFO: Deploying web application archive C:\Progress\Rollbase\Pas_Instance\webapp s\workflow.war ==>> WORKFLOW Server is starting เธ .เธ . 04, 2559 7:04:37 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.HostConfig deployDirectory INFO: Deploying web application directory C:\Progress\Rollbase\Pas_Instance\weba pps\ROOT เธ .เธ . 04, 2559 7:04:37 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.coyote.Abstr actProtocol start INFO: Starting ProtocolHandler ["http-bio-8830"] เธ .เธ . 04, 2559 7:04:37 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.coyote.Abstr actProtocol start INFO: Starting ProtocolHandler ["http-bio-8831"] เธ .เธ . 04, 2559 7:04:37 เธซเธฅเธฑเธ เน€เธ—เธตเน เธขเธ org.apache.catalina.sta rtup.Catalina start INFO: Server startup in 175259 ms
