[progress Communities] [progress Openedge Abl] Forum Post: [4.2] - Section Id Has Changed...
  • Thread starter Thread starter IramK
I
IramK
Hello, I have been using the section ID to refer to different sections because the title's of those sections are the same. In version 4.0.2, I have used the section ID directly to refer to that because both the "Section ID" and the "Original ID" were the same. However in version 4.2, the section ID is different to that of the Original ID. When I use the section ID to show or hide a section, it doesn't work. However when I use the original ID, it works. Shouldn't rollbase consider both the ID's for backward compatibility? Cheers. Iram
