* This sample extracts data from a Progress database
* and graphs the information using the Automation Objects
* from the Excel server in Office 95/97.
* You must connect to a sports database before running this.
* This sample program leaves Excel open. You should close it manually
* when the program completes.
DEFINE VARIABLE chExcelApplication AS COM-HANDLE.
DEFINE VARIABLE chWorkbook AS COM-HANDLE.
DEFINE VARIABLE chWorksheet AS COM-HANDLE.
DEFINE VARIABLE chChart AS COM-HANDLE.
DEFINE VARIABLE chWorksheetRange AS COM-HANDLE.
DEFINE VARIABLE iCount AS INTEGER.
DEFINE VARIABLE iIndex AS INTEGER.
DEFINE VARIABLE iTotalNumberOfOrders AS INTEGER.
DEFINE VARIABLE iMonth AS INTEGER.
DEFINE VARIABLE dAnnualQuota AS DECIMAL.
DEFINE VARIABLE dTotalSalesAmount AS DECIMAL.
DEFINE VARIABLE iColumn AS INTEGER INITIAL 1.
DEFINE VARIABLE cColumn AS CHARACTER.
DEFINE VARIABLE cRange AS CHARACTER.
/* create a new Excel Application object */
CREATE "Excel.Application" chExcelApplication.
/* launch Excel so it is visible to the user */
chExcelApplication:Visible = TRUE.
/* create a new Workbook */
chWorkbook = chExcelApplication:Workbooks:Add().
/* get the active Worksheet */
chWorkSheet = chExcelApplication:Sheets:Item(1).
/* set the column names for the Worksheet */
chWorkSheet:Columns("A"):ColumnWidth = 18.
chWorkSheet:Columns("B"):ColumnWidth = 12.
chWorkSheet:Columns("C"):ColumnWidth = 12.
chWorkSheet:Range("A1:C1"):Font:Bold = TRUE.
chWorkSheet:Range("A1"):Value = "SalesRep".
chWorkSheet:Range("B1"):Value = "Total Sales".
chWorkSheet:Range("C1"):Value = "Annual Quota".
/* Iterate through the salesrep table and populate
the Worksheet appropriately */
FOR EACH salesrep:
dAnnualQuota = 0.
iTotalNumberOfOrders = 0.
dTotalSalesAmount = 0.
iColumn = iColumn + 1.
FOR EACH order OF salesrep:
iTotalNumberOfOrders = iTotalNumberOfOrders + 1.
FIND invoice WHERE invoice.order-num = Order.order-num NO-ERROR.
IF AVAILABLE invoice THEN
dTotalSalesAmount = dTotalSalesAmount + invoice.amount.
END.
DO iMonth = 1 TO 12:
dAnnualQuota = dAnnualQuota + salesrep.month-quota[iMonth].
END.
cColumn = STRING(iColumn).
cRange = "A" + cColumn.
chWorkSheet:Range(cRange):Value = salesrep.rep-name.
cRange = "B" + cColumn.
chWorkSheet:Range(cRange):Value = dTotalSalesAmount.
cRange = "C" + cColumn.
chWorkSheet:Range(cRange):Value = dAnnualQuota.
END.
chWorkSheet:Range("B2:C10"):Select().
chExcelApplication:Selection:Style = "Currency".
/* create embedded chart using the data in the Worksheet */
chWorksheetRange = chWorksheet:Range("A1:C10").
chWorksheet:ChartObjects:Add(10,150,425,300):Activate.
chExcelApplication:ActiveChart:ChartWizard(chWorksheetRange, 3, 1, 2, 1, 1, TRUE,
"1996 Sales Figures", "Sales Person", "Annual Sales").
/* create chart using the data in the Worksheet */
chChart=chExcelApplication:Charts:Add().
chChart:Name = "Test Chart".
chChart:Type = 11.
/* release com-handles */
RELEASE OBJECT chExcelApplication.
RELEASE OBJECT chWorkbook.
RELEASE OBJECT chWorksheet.
RELEASE OBJECT chChart.
RELEASE OBJECT chWorksheetRange.
