Santosh Patel
Dear Ron, 1. There is no out-of-box feature to print data on to printed documents like you suggested. 2. Please explore the page level tabs feature and see if that is what you are looking for. Check out documentation.progress.com/.../index.html If not, could you pass some sample screens suggesting what you are looking for? 3. Not as of now. We are still working on enhancements to the New UI and this could be a possibility. Please post your suggestion in the ideas section. 4. You can add client-side javascript libraries as you please by adding them to the application's custom header and footer section OR add them as hosted files to the application to be included as required using template tokens. 5. We only support Amazon S3 and Microsoft Azure. Check out documentation.progress.com/.../index.html 6. You can add buttons to pages that can direct you to another page or execute client-side javascript. Check out documentation.progress.com/.../index.html 7. Hosted cloud does not allow custom JSPs, private cloud does. Having said that, your scenario can be achieved by making ajax call to another service that gives back the data required. 8. Email templates can be created which can embed report bodies and then be sent using an email trigger with timing as you please. 9. We support a lot of timing options on triggers. If direct selections are not good enough for your case, every trigger type has a formula box where you can give complex calculations governing whether the trigger should run or not. Lot of helper tokens like getCurrentDate, data manipulation and other options are available. Do get in touch with our sales team if you need help building POCs or migrating your apps to our platform.
