C
ChUIMonster
I suggest that enabling -prefecthDelay and setting -prefetchFactor 100 are simple and sensible. I mentioned in the other thread that I have not seen any downside to either. Packing the messages fuller will work better if you also set -Mm to a non-default value. -Mm 8192 is a good start. To monitor the effectiveness look at the number of records per message. You can get that from the _actServer VST. Or you can just look at the ProTop "servers" screen.
