P
Paul Mowat
Hi, Setting the timeout made no difference. After spending a bit more time we did however manage to figure out what was going wrong. When installing OE11.6 the DLC path was entered as C:\OE116\ This caused all the scripts in the bin folder to be populated with C:\OE116\ and when that was appended to other parts of the scripts it became C:\OE116\\ which caused this amongst other things not to fire as expected. I'd say that the Installshield routine needs tightened up a bit so that you can't enter the trailing slash, or if you do it's removed so it doesn't cause such problems. We uninstalled 11.6 and reinstalled it again using C:\OE116 without the trailing slash and it now works as expected. Thanks Paul
