Forum Post: Fatal Error When Running Rules Test Within Corticon 5.2
C
Christopher Ford
I am having a Java error when running a rules test in Corticon 5.2. Please help! Thanks! java.lang.RuntimeException: com.corticon.service.ccserver.exception.CcServerInvalidDecisionServiceException: CcServerImpl.compileCcServerDeploymenObject() Nested Message: com.corticon.eclipse.server.core.compile.CcJavaCompilerException: Unable to compile Java code (return value 0): Apache Ant version 1.7.1 compiled on June 27 2008 Buildfile: C:\Program Files\Corticon\Studio\configuration\com.corticon.brms\CcServerSandbox\DoNotDelete\Compilation\C01448054620371\build.xml Detected Java version: 1.6 in: C:\Program Files\Corticon\Studio\jre Detected OS: Windows 7 parsing buildfile C:\Program Files\Corticon\Studio\configuration\com.corticon.brms\CcServerSandbox\DoNotDelete\Compilation\C01448054620371\build.xml with URI = file:/C:/Program%20Files/Corticon/Studio/configuration/com.corticon.brms/CcServerSandbox/DoNotDelete/Compilation/C01448054620371/build.xml Project base dir set to: C:\Program Files\Corticon\Studio\configuration\com.corticon.brms\CcServerSandbox\DoNotDelete\Compilation\C01448054620371 [antlib:eek:rg.apache.tools.ant] Could not load definitions from resource org/apache/tools/ant/antlib.xml. It could not be found. [property] Loading C:\Program Files\Corticon\Studio\configuration\com.corticon.brms\CcServerSandbox\DoNotDelete\Compilation\C01448054620371\build.properties [property] Unable to find property file: C:\Program Files\Corticon\Studio\configuration\com.corticon.brms\CcServerSandbox\DoNotDelete\Compilation\C01448054620371\build.properties Build sequence for target(s) `compile' is [compile] Complete build sequence is [compile, ]
