Hello-We are on version 10.2B0709. We have type 2 storage areas. Database size is 350 GB. Database resides on an IBM AIX system.
We have been told by two different Progress consultants that since we are on type 2 storage areas, we should not need to do dump and loads...that doing an index rebuild will give us the same performance improvements we have typically seen after doing a dump and load. However, after doing index rebuilds, we only see slight improvements in performance...nothing as noticeable as when we used to do dump and loads.
First question - is this true that we no longer need to do dump and loads?
One reason that we have avoided doing dump and loads in the last year or so is because we have implemented a product called PRO2SQL (a Bravepoint product). It replicates data from our Progress database to a SQL reporting database. Other uesrs of PRO2SQL have told us that after doing a dump and load they have had to completely rebuild their SQL reporting database because PRO2SQL uses the rowid/recid as the unique record identifier between the Progress db and SQL.
Second question - Is there any way to do a dump and load and retain the original rowid/record ID's when the data is loaded back into the database?
Thanks.
Thanks.
