Calling Crystal from Progress.. Help..
gnome
Hi guys,
I'm trying to call Crystal Reports 9 from Progress 9.1C and There is an error upon creating the Object.
DEF VAR hCrysApp AS COM-HANDLE NO-UNDO.
CREATE "CRAXDDRT.Application" hCrysApp.
RELEASE OBJECT
hCrysApp NO-ERROR.
The automation server for CRAXDDRT.Application is not registered properly.
Please reinstall this server or try registering it again. (5893)
But I have this code working in vb6 :
Dim Report As New CRAXDDRT.Application
Private Sub Form_Load()
Screen.MousePointer = vbHourglass
CRViewer91.ReportSource = Report.OpenReport("d:\comp\app\rpts\sample.rpt")
CRViewer91.ViewReport
Screen.MousePointer = vbDefault
End Sub
fyi: I'm using Merant 3.60 3-Bit Progress SQL92 v9.1c as ODBC Driver
Hope someone can lead me to right direction.
gnome
Ok I found the solution.
should be
CREATE "CrystalDesignRuntime.Application" hCrysApp.
I just used Progress COM Object Viewer instead of MS Object Browser.
gnome
Here you go.
C:\Program Files\Common Files\Crystal Decisions\2.0\crystalreportviewers\ActiveXViewer
