Robert_Wilson
Hey Guys,
Some back story to this, I'm developing some IM chat functionality using node and Openedge 11.7. When the agents and customers message each other there is a ping to a rest endpoint through PAS to store the message in our DB. The issue I've got just now is that when the message comes in if there is, for example, a pound sign that can't be converted from UTF-8 to 1251 (our cpinternal codepage) th GetJsonText function break with Unexpected UTF-8 bit pattern 0xa0 in WRITE-JSON( ). (15353).
I'm looking to see if anyone has any pointers on how best to deal with this. I've tried converting the codepage of my long char to UTF-8 but the error persists, another idea I had was to URL encode the message data and then decode on the backend but URL-DECODE() only seems available in webspeed.
Here's a snippet of the code:
Thanks in advance,
Robert.
/* Parse the json data and pull out the required information */
ASSIGN
omp = NEW ObjectModelParser()
jsonParam = CAST(omp:Parse(icJSON),JsonObject)
cAuth = jsonParam:GetCharacter('authId')
lcImChatMsg = jsonParam:GetJsonText('messageData') //code is failing here with the above error
lAgent = LOGICAL(jsonParam:GetJsonText('isAgent')).
/* The frontend likes to escape slashes so unescape them so that dates can be read into the temp-table correctly */
ASSIGN lcImChatMsg = REPLACE(lcImChatMsg,"\/","/").
/* read the message data into the imchat temp-table */
EMPTY TEMP-TABLE ttimChat NO-ERROR.
ASSIGN hTemp = TEMP-TABLE ttimChat:DEFAULT-BUFFER-HANDLE.
hTemp:READ-JSON("LONGCHAR", lcImChatMsg).
Thanks in advance,
Robert.
