Joel W Winston
Can I use a "wait-for" in a class file or is it a bad practice or bad conceptualization?
What I am trying to achieve is design a class for a "Progress meter" (or a thermometer) which shows the progress of records being processed in a report or utility.
I would like to encapsulate the whole thing in a class. While the progress meter is running I would like to enable a 'Cancel' button which will abort the process.
I am able to achieve the above idea without a 'cancel' button. But if I have to implement a 'cancel' button I need to use 'WAIT-for' right? Where / how can I implement this 'WAIT-FOR' within the class file?
So how do I accomplish this?
I have given the class file below.
Please let me know your thoughts / suggestions.
Thanks
Joel
CLASS mast.ProgMeter:
DEFINE private VARIABLE FractionOfBar AS DECIMAL NO-UNDO.
DEFINE private VARIABLE AccumFractionOfBar AS DECIMAL NO-UNDO.
DEFINE private VARIABLE OrigWidthPixels AS DECIMAL NO-UNDO.
DEFINE private variable ErrorCode as integer no-undo.
DEFINE private variable ErrorString as character no-undo.
DEFINE private BUTTON Btn_Cancel AUTO-END-KEY
LABEL "Cancel"
SIZE 15 BY 1
BGCOLOR 8 .
DEFINE PRIVATE VARIABLE fc-thermometer AS CHARACTER FORMAT "X(256)":U
VIEW-AS TEXT
SIZE 77 BY 1
BGCOLOR 1 NO-UNDO.
DEFINE PRIVATE RECTANGLE RECT-2
EDGE-PIXELS 2 GRAPHIC-EDGE NO-FILL
SIZE 77 BY 1.1.
DEFINE PRIVATE FRAME Dialog-Frame
fc-thermometer AT ROW 1.57 COL 2 NO-LABEL WIDGET-ID 8
RECT-2 AT ROW 1.52 COL 2 WIDGET-ID 14
SPACE(0.79) SKIP(0.61)
WITH VIEW-AS DIALOG-BOX KEEP-TAB-ORDER
SIDE-LABELS NO-UNDERLINE THREE-D SCROLLABLE
TITLE "Progress Meter" WIDGET-ID 100.
CONSTRUCTOR public ProgMeter(TotalCount as decimal):
AccumFractionOfBar = 0.
OrigWidthPixels = fc-thermometer:WIDTH-PIXELS IN FRAME Dialog-Frame.
FractionOfBar = fc-thermometer:WIDTH-PIXELS IN FRAME Dialog-Frame / TotalCount.
fc-thermometer:width-pixels in frame Dialog-Frame = 1.
view frame Dialog-Frame.
END METHOD.
METHOD public logical SetMeterTitle(MeterTitle as character):
frame Dialog-Frame:title = MeterTitle.
return true.
END METHOD.
METHOD public logical IncrementMeter():
AccumFractionOfBar = AccumFractionOfBar + FractionOfBar.
if AccumFractionOfBar > OrigWidthPixels then
fc-thermometer:WIDTH-PIXELS IN FRAME Dialog-Frame = OrigWidthPixels.
else do:
if AccumFractionOfBar >= .5 then /* minimum width-pixels must be .5 */
fc-thermometer:width-pixels in frame Dialog-Frame = AccumFractionOfBar.
end.
return true.
END METHOD.
METHOD public integer ErrorCode():
return ErrorCode.
END METHOD.
METHOD public character ErrorString():
return ErrorString.
END METHOD.
DESTRUCTOR PUBLIC ProgMeter():
END METHOD.
END CLASS.
Thanks
Joel
LABEL "Cancel"
SIZE 15 BY 1
BGCOLOR 8 .
VIEW-AS TEXT
SIZE 77 BY 1
BGCOLOR 1 NO-UNDO.
SIZE 77 BY 1.1.
END METHOD.
return true.
END METHOD.
else do:
end.
return true.
END METHOD.
return ErrorCode.
END METHOD.
return ErrorString.
END METHOD.
END METHOD.
END CLASS.
