H
hbc
I'm using a character application. In first page, there is a frame f-selection where the search fields are entered. When I search for something and open some other frames in that search,then I press F10 which is for opening another frame, the new frame opens but f-selection also appears on it. I'm suspecting this code makes it pop up again :
else assign ll-lgst-key1:SENSITIVE in frame f-selection = TRUE
ll-lgst-key2:SENSITIVE in frame f-selection = FALSE
because when I comment these lines, the frame dont pop up. But then I can't use these fields at the first frame where I should, too. I don't know why this code is called again but Is there anything else to fix that issue? I tried to write hide frame f-selection to everywhere possible but It doesn't work.
