[Stackoverflow] [Progress OpenEdge ABL] How to call a mvsc dll (C++ or Rust) from Progress Open Edge
  • Thread starter Thread starter Stéphane
Stéphane
I have a dll that i want to call from Progress code but I can't complete.
I have tried with Visual Studio 2022, Windows C++ Dll and Rust Dll.
Windows C++, Visual Studio 2022 with Progress
Cpp
#include "pch.h"
#include <windows.h>
#include <string.h>
BOOL APIENTRY DllMain( HMODULE hModule,
                       DWORD  ul_reason_for_call,
                       LPVOID lpReserved
    switch (ul_reason_for_call)
    case DLL_PROCESS_ATTACH:
    case DLL_THREAD_ATTACH:
    case DLL_THREAD_DETACH:
    case DLL_PROCESS_DETACH:
        break;
    return TRUE;
BOOL WINAPI DllMain(HINSTANCE hinstDLL, DWORD fwdreason, LPVOID lpvReserved)
    return 1;
extern "C" __declspec(dllexport) int HelloWorld(int hello)
    return hello * 2;
Progress
BLOCK-LEVEL ON ERROR UNDO, THROW.
PROCEDURE HelloWorld EXTERNAL "C:\Users\Steee\source\repos\DllHelloWorld\x64\Release\DllHelloWorld.dll" CDECL:
    DEFINE INPUT PARAMETER hello AS SHORT NO-UNDO.
    DEFINE OUTPUT PARAMETER rCode AS SHORT NO-UNDO.
END.
DEFINE VARIABLE hello AS INTEGER NO-UNDO.
DEFINE VARIABLE rCode AS INTEGER NO-UNDO.
hello = 3.
RUN HelloWorld(hello, OUTPUT rCode).
MESSAGE STRING(rCode)
VIEW-AS ALERT-BOX INFO BUTTONS OK.
The code compiles without errors and warning but I've got "0" in MESSAGE STRING(rCode), this sould get "6".
Rust with mvsc with Progress
Rust lib.rs
use std::os::raw::{c_int};
#[no_mangle]
pub extern "C" fn HelloWorld(hello: c_int) -> c_int {
    hello * 2
Rust Cargo.toml
[package]
name = "DllRust"
version = "0.1.0"
edition = "2021"
# See more keys and their definitions at https://doc.rust-lang.org/cargo/reference/manifest.html
[lib]
name = "dll_rust"
crate-type = ["cdylib"]
[dependencies]
C Header
#include <stdarg.h>
#include <stdbool.h>
#include <stdint.h>
#include <stdlib.h>
int HelloWorld(int hello);
Progress
PROCEDURE DllHelloWorld EXTERNAL "C:\Users\Steee\CLionProjects\DllRust\target\release\dll_rust.dll" CDECL:
END.
hello = 3.
The code doesn't compile. "** 'HelloWorld' was not found. (293)"
