Progress V9.1D07 + XP-Style + RadioSets Problem
DarkHawk
Hi to all.
Sorry but my english isn´t so good, so iam to endeavor.
My problem is follow iam use the Windows XP Style in our Application.
Iam use the Prowin32.exe.manifest file and the Entry "useClipChildren=yes" in the Progress.ini.
The XP-Style still work perfect.
But we use insensitive radiosets, the user can not edit that, its only to show which option are selected.
This insensitive radiosets are not visible with XP-Style. On Win2000 or XP with non-XP-Style the insensitive radiosets will show correctly.
Have someone an idea?
Thanks a lot
Regards
Michael Hofmann
Hi Michael,
we have in our software this kind of feature (a radio-set not enabled) it works fine under win xp SP2 even if you use the xp-style or not.
We've just unchecked the enable property of the radio-set... that's all.
Hope it helps.
Stéphane.
thanks for reply.
I found the problem.
We use an personal background Color for our windows.
This Color is too dark, so the insensitive Radiosets have the same shadow.
With standard Color for Background it works fine.
Thanks a lot.
Regards
Michael
