Progress schema holder data mapping issue
kasundha
Hi all,
OE 12.2
MSSQL 2025
I have created a schema holder for an MSSQL DB. There is a table with a varchar field (it contains only numbers as values). I want to change the data type as Integer in openedge schema holder side. Is it possible to do it???
You can't change the data type of a field in an OpenEdge database, with one exception: changing an integer field to int64.
