[Progress News] [Progress OpenEdge ABL] Progress DataDirect OpenAccess SDK 9.0: A Leap Forward in Secure, Seamless Connectivity
  • Thread starter Thread starter Todd Wright
Todd Wright
We’re excited to announce the release of OpenAccess SDK 9.0, a major milestone in our journey to deliver secure, high-performance, and standards-compliant data connectivity. This release is packed with critical security enhancements, streamlined deployment features, and continued support for cross-platform client access—all designed to empower developers and enterprises alike.
Security-First: Built for Today’s Compliance Needs​
Security was the cornerstone of this release. With OpenAccess SDK 9.0, we’ve made significant strides to make your data access layer more robust and compliant:
  • Upgraded OpenSSL to 3.0.16, aligning with modern encryption standards.
  • Deprecated TLS v1.0 and v1.1, eliminating outdated protocols to reduce vulnerability exposure.
  • Removed legacy dependencies like msvcr100.dll and LDAP support, simplifying the runtime environment and reducing attack surfaces.
  • Bundled ICU 74.1 as a single library file, streamlining deployment and minimizing potential integration issues.
These changes reflect our commitment to delivering a secure foundation for your data connectivity infrastructure.
Upgrade Made Easy​
We know that upgrading SDKs can be daunting. That’s why OpenAccess SDK 9.0 is designed for ease of transition:
  • Backward Compatible—OpenAccess 8.1 clients can connect to the OpenAccess 9.0 server
  • Forward Compatible—OpenAccess 9.0 clients can connect to the OpenAccess 8.1 server
  • No backend changes required—your existing data source remains untouched.
  • Unified deployment—leveraging the new build environment (Visual Studio 2022 for Windows, GCC 8.5 for Linux) brings compatibility across modern platforms.
  • Simplified prerequisites—with clear guidance on Microsoft Visual C++ Redistributable, setup is straightforward and predictable.
Whether you're upgrading from 8.1 or integrating for the first time, OpenAccess SDK 9.0 makes the process smooth and reliable.
Code Once, Connect Everywhere​
One of the most powerful aspects of OpenAccess SDK is its multi-client support. With a single server implementation, you instantly unlock access for:
  • ODBC – for cross-platform compatibility
  • JDBC – for Java-based applications
  • ADO.NET – for .NET environments
If you're ready to get started, check out a Free Trial to learn how you can do this for yourself.
