[progress Communities] [progress Openedge Abl] Speed Up Index() And Substring() With...
  • Thread starter Thread starter egger
E
egger
When ABL has to read a large textfile e.g. row-by-row being read into a LONGCHAR variable it is very fast if session:cpinternal is 1252 / iso8859-1 but very slow unter UTF-8. See article http://knowledgebase.progress.com/articles/Article/000039559 When I use FIX-CODEPAGE = 1252 for the LONGCHAR it gets even worse because its different to the UTF-8 session then. When I use INDEX or SUBSTRING with that 1-byte LONGCHAR it should not need doing character conversion with cpinternal in the first place. The code-example takes milliseconds with CPINTERNAL 1252 but takes up to an hour with UTF-8. /* Example */ DEFINE VARIABLE lchar AS LONGCHAR NO-UNDO. DEFINE VARIABLE ld_bytes as deci NO-UNDO. DEFINE VARIABLE record AS CHARACTER NO-UNDO. DEFINE VARIABLE iIndex AS INTEGER NO-UNDO. DEFINE VARIABLE iPosition AS INTEGER INIT 1 NO-UNDO. FIX-CODEPAGE(lchar) = "1252". /* even if you omit this under a CPINTERNAL UTF-8 it still takes way to long */ /* LONGCHAR */ COPY-LOB FROM FILE "400000_rows.txt" TO lchar. ASSIGN ld_bytes = LENGTH(lchar). etime(true). REPEAT: ASSIGN iIndex = INDEX(lchar , CHR(13), iPosition) record = SUBSTRING(lchar, iPosition, (iIndex - iPosition)). /* do something with the record */ ASSIGN iPosition = iIndex + 2. IF iPosition >= ld_bytes THEN LEAVE. END. /* Takes milliseconds when SESSION:CPINTERNAL = 1252 and up to an hour with UTF-8 */ MESSAGE STRING(INT(ETIME / 1000),"HH:MM:SS") VIEW-AS ALERT-BOX.
