C
ctoman
How to measure restful ws calls round trip. I'm using Tim Kuehn log-manager-report, however, im trying understand the output. here is the output: TimeDiff Elapsed line-no (ms) (Sec) N Action Ret current-line ---------- - ----------- ------------ -- --------------- ---------- ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 1 16/02/22 00:15:20.760 .000 1 Logging level set to = 3 2 16/02/22 00:15:20.760 .000 1 Log entry types activated: ASPlumbing,DB.Connects 3 16/02/22 00:15:20.760 .000 2 Starting application server for webbroker. (5560) 4 16/02/22 00:15:20.760 .000 2 Application Server Startup. (5473) 5 16/02/22 00:15:20.760 .000 2 Database carolina Options: (12699) 6 16/02/22 00:15:20.760 9.00 .009 2 Connected to database carolina, user number 8412. (9543) 7 16/02/22 00:15:20.769 * 88.00 .097 3 Admin request received 8 16/02/22 00:15:20.857 .097 1 Logging level set to = 3 9 16/02/22 00:15:20.857 .097 1 Log entry types activated: ASPlumbing,DB.Connects 10 16/02/22 00:15:20.857 .097 2 Starting application server for webbroker. (5560) 11 16/02/22 00:15:20.857 .097 2 Application Server Startup. (5473) 12 16/02/22 00:15:20.857 .097 2 Database carolina Options: (12699) 13 16/02/22 00:15:20.857 1.00 .098 2 Connected to database carolina, user number 8411. (9543) 14 16/02/22 00:15:20.858 * 108.00 .206 3 Admin request received 15 16/02/22 00:15:20.966 .206 1 Logging level set to = 3 16 16/02/22 00:15:20.966 .206 1 Log entry types activated: ASPlumbing,DB.Connects 17 16/02/22 00:15:20.966 .206 2 Starting application server for webbroker. (5560) 18 16/02/22 00:15:20.966 .206 2 Application Server Startup. (5473) 19 16/02/22 00:15:20.966 .206 2 Database carolina Options: (12699) 20 16/02/22 00:15:20.966 2.00 .208 2 Connected to database carolina, user number 8410. (9543) 21 16/02/22 00:15:20.968 * 106.00 .314 3 Admin request received 22 16/02/22 00:15:21.074 .314 1 Logging level set to = 3 23 16/02/22 00:15:21.074 .314 1 Log entry types activated: ASPlumbing,DB.Connects 24 16/02/22 00:15:21.074 .314 2 Starting application server for webbroker. (5560) 25 16/02/22 00:15:21.074 .314 2 Application Server Startup. (5473) 26 16/02/22 00:15:21.074 .314 2 Database carolina Options: (12699) 27 16/02/22 00:15:21.074 1.00 .315 2 Connected to database carolina, user number 8409. (9543) 28 16/02/22 00:15:21.075 * 112.00 .427 3 Admin request received 29 16/02/22 00:15:21.187 .427 1 Logging level set to = 3 30 16/02/22 00:15:21.187 .427 1 Log entry types activated: ASPlumbing,DB.Connects 31 16/02/22 00:15:21.187 .427 2 Starting application server for webbroker. (5560) 32 16/02/22 00:15:21.187 .427 2 Application Server Startup. (5473) 33 16/02/22 00:15:21.187 .427 2 Database carolina Options: (12699) 34 16/02/22 00:15:21.187 1.00 .428 2 Connected to database carolina, user number 8408. (9543) 35 16/02/22 00:15:21.188 * 1265176.00 1265.604 3 Admin request received 36 16/02/22 00:36:26.364 * 15.00 1265.619 3 requestID= 37 16/02/22 00:36:26.379 * 8601.00 1274.220 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 38 16/02/22 00:36:34.980 * 526246.00 1800.466 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 39 16/02/22 00:45:21.226 1.00 1800.467 2 Shutdown request received. (5465) 40 16/02/22 00:45:21.227 1800.467 3 Shutdown response sent. 41 16/02/22 00:45:21.227 1800.467 2 Application Server Shutdown. (5476) 42 16/02/22 00:45:21.227 1.00 1800.468 2 Shutdown request received. (5465) 43 16/02/22 00:45:21.228 1800.468 3 Shutdown response sent. 44 16/02/22 00:45:21.228 1.00 1800.469 2 Application Server Shutdown. (5476) 45 16/02/22 00:45:21.229 1800.469 2 Shutdown request received. (5465) 46 16/02/22 00:45:21.229 1800.469 3 Shutdown response sent. 47 16/02/22 00:45:21.229 1800.469 2 Shutdown request received. (5465) 48 16/02/22 00:45:21.229 1800.469 2 Application Server Shutdown. (5476) 49 16/02/22 00:45:21.229 1.00 1800.470 3 Shutdown response sent. 50 16/02/22 00:45:21.230 * 22004924.00 23805.394 2 Application Server Shutdown. (5476) 51 16/02/22 06:52:06.154 1.00 23805.395 3 requestID= 52 16/02/22 06:52:06.155 * 115.00 23805.510 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 53 16/02/22 06:52:06.270 * 186924.00 23992.434 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 54 16/02/22 06:55:13.194 23992.434 3 requestID= 55 16/02/22 06:55:13.194 * 105.00 23992.539 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 56 16/02/22 06:55:13.299 * 110956.00 24103.495 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 57 16/02/22 06:57:04.255 24103.495 3 requestID= 58 16/02/22 06:57:04.255 * 1643.00 24105.138 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 59 16/02/22 06:57:05.898 * 151107.00 24256.245 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 60 16/02/22 06:59:37.005 24256.245 3 requestID= 61 16/02/22 06:59:37.005 * 239.00 24256.484 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 62 16/02/22 06:59:37.244 * 61667.00 24318.151 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 63 16/02/22 07:00:38.911 24318.151 3 requestID= 64 16/02/22 07:00:38.911 * 378.00 24318.529 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 65 16/02/22 07:00:39.289 * 81062.00 24399.591 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 66 16/02/22 07:02:00.351 24399.591 3 requestID= 67 16/02/22 07:02:00.351 * 2974.00 24402.565 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 68 16/02/22 07:02:03.325 * 223895.00 24626.460 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 69 16/02/22 07:05:47.220 1.00 24626.461 3 requestID= 70 16/02/22 07:05:47.221 * 352.00 24626.813 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 71 16/02/22 07:05:47.573 * 118840.00 24745.653 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 72 16/02/22 07:07:46.413 24745.653 3 requestID= 73 16/02/22 07:07:46.413 * 1505.00 24747.158 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 74 16/02/22 07:07:47.918 * 48375.00 24795.533 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 75 16/02/22 07:08:36.293 24795.533 3 requestID= 76 16/02/22 07:08:36.293 * 1605.00 24797.138 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 77 16/02/22 07:08:37.898 * 143345.00 24940.483 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 78 16/02/22 07:11:01.243 24940.483 3 requestID= 79 16/02/22 07:11:01.243 * 136.00 24940.619 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 80 16/02/22 07:11:01.379 * 162.00 24940.781 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 81 16/02/22 07:11:01.541 24940.781 3 requestID= 82 16/02/22 07:11:01.541 * 121.00 24940.902 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 83 16/02/22 07:11:01.662 * 284521.00 25225.423 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 84 16/02/22 07:15:46.183 25225.423 3 requestID= 85 16/02/22 07:15:46.183 * 172.00 25225.595 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 86 16/02/22 07:15:46.355 * 108418.00 25334.013 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 87 16/02/22 07:17:34.773 25334.013 3 requestID= 88 16/02/22 07:17:34.773 * 178.00 25334.191 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 89 16/02/22 07:17:34.951 * 201.00 25334.392 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 90 16/02/22 07:17:35.152 25334.392 3 requestID= 91 16/02/22 07:17:35.152 * 141.00 25334.533 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 92 16/02/22 07:17:35.293 * 299.00 25334.832 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 93 16/02/22 07:17:35.592 25334.832 3 requestID= 94 16/02/22 07:17:35.592 * 133.00 25334.965 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 95 16/02/22 07:17:35.725 * 17148.00 25352.113 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 96 16/02/22 07:17:52.873 25352.113 3 requestID= 97 16/02/22 07:17:52.873 * 156.00 25352.269 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 98 16/02/22 07:17:53.029 * 29284.00 25381.553 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 99 16/02/22 07:18:22.313 25381.553 3 requestID= 100 16/02/22 07:18:22.313 * 3851.00 25385.404 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 101 16/02/22 07:18:26.164 * 11319.00 25396.723 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 102 16/02/22 07:18:37.483 25396.723 3 requestID= 103 16/02/22 07:18:37.483 * 1030.00 25397.753 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 104 16/02/22 07:18:38.513 * 63330.00 25461.083 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 105 16/02/22 07:19:41.843 25461.083 3 requestID= 106 16/02/22 07:19:41.843 * 131.00 25461.214 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 107 16/02/22 07:19:41.974 * 209299.00 25670.513 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 108 16/02/22 07:23:11.273 25670.513 3 requestID= 109 16/02/22 07:23:11.273 * 174.00 25670.687 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 110 16/02/22 07:23:11.447 * 1966.00 25672.653 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 111 16/02/22 07:23:13.413 25672.653 3 requestID= 112 16/02/22 07:23:13.413 * 1340.00 25673.993 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 113 16/02/22 07:23:14.753 * 38630.00 25712.623 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 114 16/02/22 07:23:53.383 25712.623 3 requestID= 115 16/02/22 07:23:53.383 * 146.00 25712.769 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 116 16/02/22 07:23:53.529 * 449384.00 26162.153 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 117 16/02/22 07:31:22.913 26162.153 3 requestID= 118 16/02/22 07:31:22.913 * 14489.00 26176.642 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 119 16/02/22 07:31:37.402 * 66471.00 26243.113 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 120 16/02/22 07:32:43.873 26243.113 3 requestID= 121 16/02/22 07:32:43.873 * 3373.00 26246.486 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 122 16/02/22 07:32:47.246 * 267447.00 26513.933 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 123 16/02/22 07:37:14.693 26513.933 3 requestID= 124 16/02/22 07:37:14.693 * 22.00 26513.955 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 125 16/02/22 07:37:14.715 * 66658.00 26580.613 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 126 16/02/22 07:38:21.373 26580.613 3 requestID= 127 16/02/22 07:38:21.373 * 3229.00 26583.842 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 128 16/02/22 07:38:24.602 * 57771.00 26641.613 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 129 16/02/22 07:39:22.373 26641.613 3 requestID= 130 16/02/22 07:39:22.373 * 483.00 26642.096 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 131 16/02/22 07:39:22.856 * 68757.00 26710.853 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 132 16/02/22 07:40:31.613 26710.853 3 requestID= 133 16/02/22 07:40:31.613 * 4050.00 26714.903 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 134 16/02/22 07:40:35.663 * 36170.00 26751.073 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 135 16/02/22 07:41:11.833 26751.073 3 requestID= 136 16/02/22 07:41:11.833 * 2913.00 26753.986 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 137 16/02/22 07:41:14.746 * 6677.00 26760.663 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 138 16/02/22 07:41:21.423 26760.663 3 requestID= 139 16/02/22 07:41:21.423 * 2484.00 26763.147 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 140 16/02/22 07:41:23.907 * 5266.00 26768.413 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 141 16/02/22 07:41:29.173 26768.413 3 requestID= 142 16/02/22 07:41:29.173 * 98.00 26768.511 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 143 16/02/22 07:41:29.271 * 160.00 26768.671 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 144 16/02/22 07:41:29.431 26768.671 3 requestID= 145 16/02/22 07:41:29.431 * 138.00 26768.809 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 146 16/02/22 07:41:29.569 * 53324.00 26822.133 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 147 16/02/22 07:42:22.893 26822.133 3 requestID= 148 16/02/22 07:42:22.893 * 984.00 26823.117 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 149 16/02/22 07:42:23.877 * 4876.00 26827.993 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 150 16/02/22 07:42:28.753 26827.993 3 requestID= 151 16/02/22 07:42:28.753 * 539.00 26828.532 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 152 16/02/22 07:42:29.292 * 3531.00 26832.063 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 153 16/02/22 07:42:32.823 26832.063 3 requestID= 154 16/02/22 07:42:32.823 * 522.00 26832.585 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 155 16/02/22 07:42:33.345 * 75318.00 26907.903 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 156 16/02/22 07:43:48.663 26907.903 3 requestID= 157 16/02/22 07:43:48.663 * 900.00 26908.803 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 158 16/02/22 07:43:49.563 * 54790.00 26963.593 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 159 16/02/22 07:44:44.353 26963.593 3 requestID= 160 16/02/22 07:44:44.353 * 16.00 26963.609 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 161 16/02/22 07:44:44.369 * 5004.00 26968.613 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 162 16/02/22 07:44:49.373 26968.613 3 requestID= 163 16/02/22 07:44:49.373 * 18.00 26968.631 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 164 16/02/22 07:44:49.391 * 4702.00 26973.333 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 165 16/02/22 07:44:54.093 26973.333 3 requestID= 166 16/02/22 07:44:54.093 * 2915.00 26976.248 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 167 16/02/22 07:44:57.008 * 15075.00 26991.323 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 168 16/02/22 07:45:12.083 26991.323 3 requestID= 169 16/02/22 07:45:12.083 * 2626.00 26993.949 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 170 16/02/22 07:45:14.709 * 33684.00 27027.633 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 171 16/02/22 07:45:48.393 27027.633 3 requestID= 172 16/02/22 07:45:48.393 * 526.00 27028.159 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 173 16/02/22 07:45:48.919 * 6654.00 27034.813 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 174 16/02/22 07:45:55.573 27034.813 3 requestID= 175 16/02/22 07:45:55.573 * 550.00 27035.363 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 176 16/02/22 07:45:56.123 * 49050.00 27084.413 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 177 16/02/22 07:46:45.173 27084.413 3 requestID= 178 16/02/22 07:46:45.173 * 4433.00 27088.846 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 179 16/02/22 07:46:49.606 * 57097.00 27145.943 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 180 16/02/22 07:47:46.703 27145.943 3 requestID= 181 16/02/22 07:47:46.703 * 4066.00 27150.009 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 182 16/02/22 07:47:50.769 * 90884.00 27240.893 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 183 16/02/22 07:49:21.653 27240.893 3 requestID= 184 16/02/22 07:49:21.653 * 4477.00 27245.370 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 185 16/02/22 07:49:26.130 * 187433.00 27432.803 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 186 16/02/22 07:52:33.563 27432.803 3 requestID= 187 16/02/22 07:52:33.563 * 2262.00 27435.065 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 188 16/02/22 07:52:35.825 * 12518.00 27447.583 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 189 16/02/22 07:52:48.343 27447.583 3 requestID= 190 16/02/22 07:52:48.343 * 168.00 27447.751 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 191 16/02/22 07:52:48.511 * 104152.00 27551.903 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 192 16/02/22 07:54:32.663 27551.903 3 requestID= 193 16/02/22 07:54:32.663 * 1553.00 27553.456 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 194 16/02/22 07:54:34.216 * 11117.00 27564.573 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 195 16/02/22 07:54:45.333 27564.573 3 requestID= 196 16/02/22 07:54:45.333 * 832.00 27565.405 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 197 16/02/22 07:54:46.165 * 118948.00 27684.353 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 198 16/02/22 07:56:45.113 27684.353 3 requestID= 199 16/02/22 07:56:45.113 * 805.00 27685.158 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 200 16/02/22 07:56:45.918 * 144105.00 27829.263 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 201 16/02/22 07:59:10.023 27829.263 3 requestID= 202 16/02/22 07:59:10.023 * 270.00 27829.533 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 203 16/02/22 07:59:10.293 * 6370.00 27835.903 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 204 16/02/22 07:59:16.663 27835.903 3 requestID= 205 16/02/22 07:59:16.663 * 864.00 27836.767 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 206 16/02/22 07:59:17.527 * 83139.00 27919.906 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 207 16/02/22 08:00:40.666 27919.906 3 requestID= 208 16/02/22 08:00:40.666 * 4389.00 27924.295 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 209 16/02/22 08:00:45.055 * 87771.00 28012.066 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 210 16/02/22 08:02:12.826 28012.066 3 requestID= 211 16/02/22 08:02:12.826 * 925.00 28012.991 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 212 16/02/22 08:02:13.751 * 268624.00 28281.615 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 213 16/02/22 08:06:42.375 28281.615 3 requestID= 214 16/02/22 08:06:42.375 * 206.00 28281.821 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 215 16/02/22 08:06:42.581 * 447602.00 28729.423 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 216 16/02/22 08:14:10.183 1.00 28729.424 3 requestID= 217 16/02/22 08:14:10.184 * 101.00 28729.525 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 218 16/02/22 08:14:10.285 * 1164399.00 29893.924 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 219 16/02/22 08:33:34.684 8.00 29893.932 3 requestID= 220 16/02/22 08:33:34.692 * 4266.00 29898.198 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 221 16/02/22 08:33:38.958 * 160846.00 30059.044 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 222 16/02/22 08:36:19.804 30059.044 3 requestID= 223 16/02/22 08:36:19.804 * 4319.00 30063.363 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 224 16/02/22 08:36:24.123 * 17031.00 30080.394 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 225 16/02/22 08:36:41.154 30080.394 3 requestID= 226 16/02/22 08:36:41.154 * 4319.00 30084.713 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 227 16/02/22 08:36:45.473 * 29761.00 30114.474 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 228 16/02/22 08:37:15.234 30114.474 3 requestID= 229 16/02/22 08:37:15.234 * 3241.00 30117.715 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 230 16/02/22 08:37:18.475 * 45919.00 30163.634 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 231 16/02/22 08:38:04.394 30163.634 3 requestID= 232 16/02/22 08:38:04.394 * 875.00 30164.509 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 233 16/02/22 08:38:05.269 * 112495.00 30277.004 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 234 16/02/22 08:39:57.764 30277.004 3 requestID= 235 16/02/22 08:39:57.764 * 3467.00 30280.471 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 236 16/02/22 08:40:01.231 * 105433.00 30385.904 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 237 16/02/22 08:41:46.664 30385.904 3 requestID= 238 16/02/22 08:41:46.664 * 3499.00 30389.403 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 239 16/02/22 08:41:50.163 * 4021.00 30393.424 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 240 16/02/22 08:41:54.184 30393.424 3 requestID= 241 16/02/22 08:41:54.184 * 1378.00 30394.802 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 242 16/02/22 08:41:55.562 * 3952.00 30398.754 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 243 16/02/22 08:41:59.514 30398.754 3 requestID= 244 16/02/22 08:41:59.514 * 1172.00 30399.926 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 245 16/02/22 08:42:00.686 * 148988.00 30548.914 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 246 16/02/22 08:44:29.674 30548.914 3 requestID= 247 16/02/22 08:44:29.674 * 13269.00 30562.183 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 248 16/02/22 08:44:42.943 * 250261.00 30812.444 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 249 16/02/22 08:48:53.204 30812.444 3 requestID= 250 16/02/22 08:48:53.204 * 5736.00 30818.180 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 251 16/02/22 08:48:58.940 * 244335.00 31062.515 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 252 16/02/22 08:53:03.275 31062.515 3 requestID= 253 16/02/22 08:53:03.275 * 13046.00 31075.561 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 254 16/02/22 08:53:16.321 * 638739.00 31714.300 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 255 16/02/22 09:03:55.060 31714.300 3 requestID= 256 16/02/22 09:03:55.060 * 3948.00 31718.248 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 257 16/02/22 09:03:59.008 * 7782.00 31726.030 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 258 16/02/22 09:04:06.790 31726.030 3 requestID= 259 16/02/22 09:04:06.790 * 174.00 31726.204 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 260 16/02/22 09:04:06.964 * 240.00 31726.444 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 261 16/02/22 09:04:07.204 31726.444 3 requestID= 262 16/02/22 09:04:07.204 * 136.00 31726.580 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 263 16/02/22 09:04:07.340 * 40380.00 31766.960 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 264 16/02/22 09:04:47.720 31766.960 3 requestID= 265 16/02/22 09:04:47.720 * 142.00 31767.102 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 266 16/02/22 09:04:47.862 * 23688.00 31790.790 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 267 16/02/22 09:05:11.550 31790.790 3 requestID= 268 16/02/22 09:05:11.550 * 141.00 31790.931 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 269 16/02/22 09:05:11.691 * 83099.00 31874.030 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 270 16/02/22 09:06:34.790 31874.030 3 requestID= 271 16/02/22 09:06:34.790 * 129.00 31874.159 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 272 16/02/22 09:06:34.919 * 512321.00 32386.480 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 273 16/02/22 09:15:07.240 32386.480 3 requestID= 274 16/02/22 09:15:07.240 * 5443.00 32391.923 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 275 16/02/22 09:15:12.683 * 40037.00 32431.960 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 276 16/02/22 09:15:52.720 32431.960 3 requestID= 277 16/02/22 09:15:52.720 * 83.00 32432.043 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 278 16/02/22 09:15:52.803 * 40987.00 32473.030 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 279 16/02/22 09:16:33.790 32473.030 3 requestID= 280 16/02/22 09:16:33.790 * 2557.00 32475.587 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 281 16/02/22 09:16:36.347 * 183493.00 32659.080 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 282 16/02/22 09:19:39.840 32659.080 3 requestID= 283 16/02/22 09:19:39.840 * 172.00 32659.252 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 284 16/02/22 09:19:40.012 * 137647.00 32796.899 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 285 16/02/22 09:21:57.659 32796.899 3 requestID= 286 16/02/22 09:21:57.659 * 383.00 32797.282 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 287 16/02/22 09:21:58.042 * 104877.00 32902.159 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 288 16/02/22 09:23:42.919 32902.159 3 requestID= 289 16/02/22 09:23:42.919 * 561.00 32902.720 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 290 16/02/22 09:23:43.480 * 169981.00 33072.701 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 291 16/02/22 09:26:33.461 33072.701 3 requestID= 292 16/02/22 09:26:33.461 * 754.00 33073.455 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 293 16/02/22 09:26:34.215 * 14006.00 33087.461 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 294 16/02/22 09:26:48.221 33087.461 3 requestID= 295 16/02/22 09:26:48.221 * 741.00 33088.202 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 296 16/02/22 09:26:48.962 * 5649.00 33093.851 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 297 16/02/22 09:26:54.611 33093.851 3 requestID= 298 16/02/22 09:26:54.611 * 1073.00 33094.924 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 299 16/02/22 09:26:55.684 * 2747.00 33097.671 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 300 16/02/22 09:26:58.431 33097.671 3 requestID= 301 16/02/22 09:26:58.431 * 543.00 33098.214 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 302 16/02/22 09:26:58.974 * 490867.00 33589.081 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 303 16/02/22 09:35:09.841 33589.081 3 requestID= 304 16/02/22 09:35:09.841 * 444.00 33589.525 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 305 16/02/22 09:35:10.285 * 2936.00 33592.461 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 306 16/02/22 09:35:13.221 33592.461 3 requestID= 307 16/02/22 09:35:13.221 * 757.00 33593.218 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 308 16/02/22 09:35:13.978 * 86063.00 33679.281 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 309 16/02/22 09:36:40.041 33679.281 3 requestID= 310 16/02/22 09:36:40.041 * 124.00 33679.405 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 311 16/02/22 09:36:40.165 * 179316.00 33858.721 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 312 16/02/22 09:39:39.481 33858.721 3 requestID= 313 16/02/22 09:39:39.481 * 2116.00 33860.837 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 314 16/02/22 09:39:41.597 * 4744.00 33865.581 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 315 16/02/22 09:39:46.341 33865.581 3 requestID= 316 16/02/22 09:39:46.341 * 511.00 33866.092 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 317 16/02/22 09:39:46.852 * 7029.00 33873.121 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 318 16/02/22 09:39:53.881 33873.121 3 requestID= 319 16/02/22 09:39:53.881 * 691.00 33873.812 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 320 16/02/22 09:39:54.572 * 7629.00 33881.441 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 321 16/02/22 09:40:02.201 33881.441 3 requestID= 322 16/02/22 09:40:02.201 * 493.00 33881.934 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 323 16/02/22 09:40:02.694 * 25477.00 33907.411 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 324 16/02/22 09:40:28.171 33907.411 3 requestID= 325 16/02/22 09:40:28.171 * 407.00 33907.818 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 326 16/02/22 09:40:28.578 * 5743.00 33913.561 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 327 16/02/22 09:40:34.321 33913.561 3 requestID= 328 16/02/22 09:40:34.321 * 122.00 33913.683 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 329 16/02/22 09:40:34.443 * 86588.00 34000.271 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 330 16/02/22 09:42:01.031 34000.271 3 requestID= 331 16/02/22 09:42:01.031 * 264.00 34000.535 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 332 16/02/22 09:42:01.295 * 56335.00 34056.870 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 333 16/02/22 09:42:57.630 34056.870 3 requestID= 334 16/02/22 09:42:57.630 * 681.00 34057.551 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 335 16/02/22 09:42:58.311 * 95119.00 34152.670 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 336 16/02/22 09:44:33.430 34152.670 3 requestID= 337 16/02/22 09:44:33.430 * 1813.00 34154.483 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 338 16/02/22 09:44:35.243 * 6687.00 34161.170 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 339 16/02/22 09:44:41.930 34161.170 3 requestID= 340 16/02/22 09:44:41.930 * 897.00 34162.067 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 341 16/02/22 09:44:42.827 * 14113.00 34176.180 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 342 16/02/22 09:44:56.940 34176.180 3 requestID= 343 16/02/22 09:44:56.940 * 934.00 34177.114 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 344 16/02/22 09:44:57.874 * 392226.00 34569.340 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 345 16/02/22 09:51:30.100 34569.340 3 requestID= 346 16/02/22 09:51:30.100 * 764.00 34570.104 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 347 16/02/22 09:51:30.864 * 268006.00 34838.110 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 348 16/02/22 09:55:58.870 34838.110 3 requestID= 349 16/02/22 09:55:58.870 * 536.00 34838.646 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 350 16/02/22 09:55:59.406 * 106474.00 34945.120 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 351 16/02/22 09:57:45.880 34945.120 3 requestID= 352 16/02/22 09:57:45.880 * 4306.00 34949.426 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 353 16/02/22 09:57:50.186 * 155462.00 35104.888 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 354 16/02/22 10:00:25.648 35104.888 3 requestID= 355 16/02/22 10:00:25.648 * 252.00 35105.140 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 356 16/02/22 10:00:25.900 * 127138.00 35232.278 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 357 16/02/22 10:02:33.038 35232.278 3 requestID= 358 16/02/22 10:02:33.038 * 1381.00 35233.659 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 359 16/02/22 10:02:34.419 .000 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 360 .000 ************************************************************************************************************************************ Long events ************************************************************************************************************************************ TimeDiff Elapsed line-no (ms) (Sec) N Action Ret current-line ---------- - ----------- ------------ -- --------------- ---------- ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- 7 16/02/22 00:15:20.769 * 88.00 .097 3 Admin request received 14 16/02/22 00:15:20.858 * 108.00 .206 3 Admin request received 21 16/02/22 00:15:20.968 * 106.00 .314 3 Admin request received 28 16/02/22 00:15:21.075 * 112.00 .427 3 Admin request received 35 16/02/22 00:15:21.188 * 1265176.00 1265.604 3 Admin request received 36 16/02/22 00:36:26.364 * 15.00 1265.619 3 requestID= 37 16/02/22 00:36:26.379 * 8601.00 1274.220 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 38 16/02/22 00:36:34.980 * 526246.00 1800.466 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 50 16/02/22 00:45:21.230 * 22004924.00 23805.394 2 Application Server Shutdown. (5476) 52 16/02/22 06:52:06.155 * 115.00 23805.510 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 53 16/02/22 06:52:06.270 * 186924.00 23992.434 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 55 16/02/22 06:55:13.194 * 105.00 23992.539 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 56 16/02/22 06:55:13.299 * 110956.00 24103.495 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 58 16/02/22 06:57:04.255 * 1643.00 24105.138 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 59 16/02/22 06:57:05.898 * 151107.00 24256.245 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 61 16/02/22 06:59:37.005 * 239.00 24256.484 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 62 16/02/22 06:59:37.244 * 61667.00 24318.151 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 64 16/02/22 07:00:38.911 * 378.00 24318.529 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 65 16/02/22 07:00:39.289 * 81062.00 24399.591 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 67 16/02/22 07:02:00.351 * 2974.00 24402.565 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 68 16/02/22 07:02:03.325 * 223895.00 24626.460 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 70 16/02/22 07:05:47.221 * 352.00 24626.813 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 71 16/02/22 07:05:47.573 * 118840.00 24745.653 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 73 16/02/22 07:07:46.413 * 1505.00 24747.158 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 74 16/02/22 07:07:47.918 * 48375.00 24795.533 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 76 16/02/22 07:08:36.293 * 1605.00 24797.138 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 77 16/02/22 07:08:37.898 * 143345.00 24940.483 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 79 16/02/22 07:11:01.243 * 136.00 24940.619 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 80 16/02/22 07:11:01.379 * 162.00 24940.781 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 82 16/02/22 07:11:01.541 * 121.00 24940.902 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 83 16/02/22 07:11:01.662 * 284521.00 25225.423 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 85 16/02/22 07:15:46.183 * 172.00 25225.595 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 86 16/02/22 07:15:46.355 * 108418.00 25334.013 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 88 16/02/22 07:17:34.773 * 178.00 25334.191 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 89 16/02/22 07:17:34.951 * 201.00 25334.392 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 91 16/02/22 07:17:35.152 * 141.00 25334.533 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 92 16/02/22 07:17:35.293 * 299.00 25334.832 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 94 16/02/22 07:17:35.592 * 133.00 25334.965 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 95 16/02/22 07:17:35.725 * 17148.00 25352.113 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 97 16/02/22 07:17:52.873 * 156.00 25352.269 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 98 16/02/22 07:17:53.029 * 29284.00 25381.553 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 100 16/02/22 07:18:22.313 * 3851.00 25385.404 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 101 16/02/22 07:18:26.164 * 11319.00 25396.723 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 103 16/02/22 07:18:37.483 * 1030.00 25397.753 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 104 16/02/22 07:18:38.513 * 63330.00 25461.083 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 106 16/02/22 07:19:41.843 * 131.00 25461.214 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 107 16/02/22 07:19:41.974 * 209299.00 25670.513 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 109 16/02/22 07:23:11.273 * 174.00 25670.687 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 110 16/02/22 07:23:11.447 * 1966.00 25672.653 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 112 16/02/22 07:23:13.413 * 1340.00 25673.993 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 113 16/02/22 07:23:14.753 * 38630.00 25712.623 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 115 16/02/22 07:23:53.383 * 146.00 25712.769 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 116 16/02/22 07:23:53.529 * 449384.00 26162.153 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 118 16/02/22 07:31:22.913 * 14489.00 26176.642 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 119 16/02/22 07:31:37.402 * 66471.00 26243.113 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 121 16/02/22 07:32:43.873 * 3373.00 26246.486 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 122 16/02/22 07:32:47.246 * 267447.00 26513.933 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 124 16/02/22 07:37:14.693 * 22.00 26513.955 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 125 16/02/22 07:37:14.715 * 66658.00 26580.613 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 127 16/02/22 07:38:21.373 * 3229.00 26583.842 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 128 16/02/22 07:38:24.602 * 57771.00 26641.613 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 130 16/02/22 07:39:22.373 * 483.00 26642.096 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 131 16/02/22 07:39:22.856 * 68757.00 26710.853 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 133 16/02/22 07:40:31.613 * 4050.00 26714.903 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 134 16/02/22 07:40:35.663 * 36170.00 26751.073 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 136 16/02/22 07:41:11.833 * 2913.00 26753.986 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 137 16/02/22 07:41:14.746 * 6677.00 26760.663 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 139 16/02/22 07:41:21.423 * 2484.00 26763.147 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 140 16/02/22 07:41:23.907 * 5266.00 26768.413 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 142 16/02/22 07:41:29.173 * 98.00 26768.511 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 143 16/02/22 07:41:29.271 * 160.00 26768.671 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 145 16/02/22 07:41:29.431 * 138.00 26768.809 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 146 16/02/22 07:41:29.569 * 53324.00 26822.133 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 148 16/02/22 07:42:22.893 * 984.00 26823.117 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 149 16/02/22 07:42:23.877 * 4876.00 26827.993 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 151 16/02/22 07:42:28.753 * 539.00 26828.532 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 152 16/02/22 07:42:29.292 * 3531.00 26832.063 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 154 16/02/22 07:42:32.823 * 522.00 26832.585 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 155 16/02/22 07:42:33.345 * 75318.00 26907.903 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 157 16/02/22 07:43:48.663 * 900.00 26908.803 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 158 16/02/22 07:43:49.563 * 54790.00 26963.593 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 160 16/02/22 07:44:44.353 * 16.00 26963.609 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 161 16/02/22 07:44:44.369 * 5004.00 26968.613 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 163 16/02/22 07:44:49.373 * 18.00 26968.631 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 164 16/02/22 07:44:49.391 * 4702.00 26973.333 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 166 16/02/22 07:44:54.093 * 2915.00 26976.248 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 167 16/02/22 07:44:57.008 * 15075.00 26991.323 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 169 16/02/22 07:45:12.083 * 2626.00 26993.949 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 170 16/02/22 07:45:14.709 * 33684.00 27027.633 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 172 16/02/22 07:45:48.393 * 526.00 27028.159 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 173 16/02/22 07:45:48.919 * 6654.00 27034.813 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 175 16/02/22 07:45:55.573 * 550.00 27035.363 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 176 16/02/22 07:45:56.123 * 49050.00 27084.413 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 178 16/02/22 07:46:45.173 * 4433.00 27088.846 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 179 16/02/22 07:46:49.606 * 57097.00 27145.943 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 181 16/02/22 07:47:46.703 * 4066.00 27150.009 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 182 16/02/22 07:47:50.769 * 90884.00 27240.893 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 184 16/02/22 07:49:21.653 * 4477.00 27245.370 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 185 16/02/22 07:49:26.130 * 187433.00 27432.803 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 187 16/02/22 07:52:33.563 * 2262.00 27435.065 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 188 16/02/22 07:52:35.825 * 12518.00 27447.583 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 190 16/02/22 07:52:48.343 * 168.00 27447.751 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 191 16/02/22 07:52:48.511 * 104152.00 27551.903 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 193 16/02/22 07:54:32.663 * 1553.00 27553.456 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 194 16/02/22 07:54:34.216 * 11117.00 27564.573 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 196 16/02/22 07:54:45.333 * 832.00 27565.405 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 197 16/02/22 07:54:46.165 * 118948.00 27684.353 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 199 16/02/22 07:56:45.113 * 805.00 27685.158 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 200 16/02/22 07:56:45.918 * 144105.00 27829.263 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 202 16/02/22 07:59:10.023 * 270.00 27829.533 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 203 16/02/22 07:59:10.293 * 6370.00 27835.903 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 205 16/02/22 07:59:16.663 * 864.00 27836.767 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 206 16/02/22 07:59:17.527 * 83139.00 27919.906 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 208 16/02/22 08:00:40.666 * 4389.00 27924.295 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 209 16/02/22 08:00:45.055 * 87771.00 28012.066 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 211 16/02/22 08:02:12.826 * 925.00 28012.991 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 212 16/02/22 08:02:13.751 * 268624.00 28281.615 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 214 16/02/22 08:06:42.375 * 206.00 28281.821 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 215 16/02/22 08:06:42.581 * 447602.00 28729.423 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 217 16/02/22 08:14:10.184 * 101.00 28729.525 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 218 16/02/22 08:14:10.285 * 1164399.00 29893.924 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 220 16/02/22 08:33:34.692 * 4266.00 29898.198 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 221 16/02/22 08:33:38.958 * 160846.00 30059.044 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 223 16/02/22 08:36:19.804 * 4319.00 30063.363 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 224 16/02/22 08:36:24.123 * 17031.00 30080.394 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 226 16/02/22 08:36:41.154 * 4319.00 30084.713 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 227 16/02/22 08:36:45.473 * 29761.00 30114.474 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 229 16/02/22 08:37:15.234 * 3241.00 30117.715 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 230 16/02/22 08:37:18.475 * 45919.00 30163.634 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 232 16/02/22 08:38:04.394 * 875.00 30164.509 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 233 16/02/22 08:38:05.269 * 112495.00 30277.004 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 235 16/02/22 08:39:57.764 * 3467.00 30280.471 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 236 16/02/22 08:40:01.231 * 105433.00 30385.904 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 238 16/02/22 08:41:46.664 * 3499.00 30389.403 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 239 16/02/22 08:41:50.163 * 4021.00 30393.424 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 241 16/02/22 08:41:54.184 * 1378.00 30394.802 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 242 16/02/22 08:41:55.562 * 3952.00 30398.754 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 244 16/02/22 08:41:59.514 * 1172.00 30399.926 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 245 16/02/22 08:42:00.686 * 148988.00 30548.914 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 247 16/02/22 08:44:29.674 * 13269.00 30562.183 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 248 16/02/22 08:44:42.943 * 250261.00 30812.444 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 250 16/02/22 08:48:53.204 * 5736.00 30818.180 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 251 16/02/22 08:48:58.940 * 244335.00 31062.515 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 253 16/02/22 08:53:03.275 * 13046.00 31075.561 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 254 16/02/22 08:53:16.321 * 638739.00 31714.300 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 256 16/02/22 09:03:55.060 * 3948.00 31718.248 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 257 16/02/22 09:03:59.008 * 7782.00 31726.030 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 259 16/02/22 09:04:06.790 * 174.00 31726.204 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 260 16/02/22 09:04:06.964 * 240.00 31726.444 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 262 16/02/22 09:04:07.204 * 136.00 31726.580 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 263 16/02/22 09:04:07.340 * 40380.00 31766.960 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 265 16/02/22 09:04:47.720 * 142.00 31767.102 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 266 16/02/22 09:04:47.862 * 23688.00 31790.790 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 268 16/02/22 09:05:11.550 * 141.00 31790.931 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 269 16/02/22 09:05:11.691 * 83099.00 31874.030 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 271 16/02/22 09:06:34.790 * 129.00 31874.159 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 272 16/02/22 09:06:34.919 * 512321.00 32386.480 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 274 16/02/22 09:15:07.240 * 5443.00 32391.923 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 275 16/02/22 09:15:12.683 * 40037.00 32431.960 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 277 16/02/22 09:15:52.720 * 83.00 32432.043 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 278 16/02/22 09:15:52.803 * 40987.00 32473.030 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 280 16/02/22 09:16:33.790 * 2557.00 32475.587 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 281 16/02/22 09:16:36.347 * 183493.00 32659.080 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 283 16/02/22 09:19:39.840 * 172.00 32659.252 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 284 16/02/22 09:19:40.012 * 137647.00 32796.899 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 286 16/02/22 09:21:57.659 * 383.00 32797.282 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 287 16/02/22 09:21:58.042 * 104877.00 32902.159 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 289 16/02/22 09:23:42.919 * 561.00 32902.720 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 290 16/02/22 09:23:43.480 * 169981.00 33072.701 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 292 16/02/22 09:26:33.461 * 754.00 33073.455 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 293 16/02/22 09:26:34.215 * 14006.00 33087.461 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 295 16/02/22 09:26:48.221 * 741.00 33088.202 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 296 16/02/22 09:26:48.962 * 5649.00 33093.851 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 298 16/02/22 09:26:54.611 * 1073.00 33094.924 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 299 16/02/22 09:26:55.684 * 2747.00 33097.671 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 301 16/02/22 09:26:58.431 * 543.00 33098.214 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 302 16/02/22 09:26:58.974 * 490867.00 33589.081 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 304 16/02/22 09:35:09.841 * 444.00 33589.525 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 305 16/02/22 09:35:10.285 * 2936.00 33592.461 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 307 16/02/22 09:35:13.221 * 757.00 33593.218 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 308 16/02/22 09:35:13.978 * 86063.00 33679.281 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 310 16/02/22 09:36:40.041 * 124.00 33679.405 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 311 16/02/22 09:36:40.165 * 179316.00 33858.721 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 313 16/02/22 09:39:39.481 * 2116.00 33860.837 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 314 16/02/22 09:39:41.597 * 4744.00 33865.581 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 316 16/02/22 09:39:46.341 * 511.00 33866.092 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 317 16/02/22 09:39:46.852 * 7029.00 33873.121 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 319 16/02/22 09:39:53.881 * 691.00 33873.812 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 320 16/02/22 09:39:54.572 * 7629.00 33881.441 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 322 16/02/22 09:40:02.201 * 493.00 33881.934 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 323 16/02/22 09:40:02.694 * 25477.00 33907.411 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 325 16/02/22 09:40:28.171 * 407.00 33907.818 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 326 16/02/22 09:40:28.578 * 5743.00 33913.561 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 328 16/02/22 09:40:34.321 * 122.00 33913.683 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 329 16/02/22 09:40:34.443 * 86588.00 34000.271 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 331 16/02/22 09:42:01.031 * 264.00 34000.535 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 332 16/02/22 09:42:01.295 * 56335.00 34056.870 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 334 16/02/22 09:42:57.630 * 681.00 34057.551 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 335 16/02/22 09:42:58.311 * 95119.00 34152.670 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 337 16/02/22 09:44:33.430 * 1813.00 34154.483 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 338 16/02/22 09:44:35.243 * 6687.00 34161.170 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 340 16/02/22 09:44:41.930 * 897.00 34162.067 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 341 16/02/22 09:44:42.827 * 14113.00 34176.180 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 343 16/02/22 09:44:56.940 * 934.00 34177.114 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 344 16/02/22 09:44:57.874 * 392226.00 34569.340 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 346 16/02/22 09:51:30.100 * 764.00 34570.104 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 347 16/02/22 09:51:30.864 * 268006.00 34838.110 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 349 16/02/22 09:55:58.870 * 536.00 34838.646 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 350 16/02/22 09:55:59.406 * 106474.00 34945.120 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 352 16/02/22 09:57:45.880 * 4306.00 34949.426 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 353 16/02/22 09:57:50.186 * 155462.00 35104.888 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 355 16/02/22 10:00:25.648 * 252.00 35105.140 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498) 356 16/02/22 10:00:25.900 * 127138.00 35232.278 3 -- TRACE: Non-PERSISTENT Procedure END SUCCESS. (8397) 358 16/02/22 10:02:33.038 * 1381.00 35233.659 3 -- TRACE: Non-PERSISTENT Procedure 'wspostparmrest.p' START. (5498)
