[progress Communities] [progress Openedge Abl] Forum Post: Re: Xsd To Temp-tables/dataset???
  • Thread starter Thread starter Robin Brown
Robin Brown
The point here is that every complexType in a WSDL's xsd will not be mapped to a ProDataSet.. If the WSDL Analyzer fails to generate ABL templates for you to use, then there might be a bug. You might want to log an issue with tech support to get this sorted out. Regards, Robin
