[progress Communities] [progress Openedge Abl] Forum Post: Re: Xsd To Temp-tables/dataset???
  • Thread starter Thread starter Robin Brown
Robin Brown
So what is the xsd definition for DecimalOrEmpty? If bproxsdto4gl cannot map the element to a dataset(temp-tables are only accepted with Progress WSDL's), then you get a LONGCHAR? Or does bproxsdto4gl fail to generate anything?
