[progress Communities] [progress Openedge Abl] Forum Post: Re: X-document Load Function...
  • Thread starter Thread starter Ken McIntosh
K
Ken McIntosh
Hi Karikalan, Not sure what *exactly* your question is. Are you saying simply having in the XML causes an error, or something in the "Nested nodes..."? The value of ERROR-STATUS:GET-MESSAGE(1) should tell you more about the error. What have you used to validate the XML you're loading? You can paste or upload your XML to http://www.xmlvalidation.com to check for errors. Regards, Ken Mc
