[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: why does IServiceManager:getService not return IService instead of P.L.Object
marian.edu
The only problem there Jan is how do you know, from generic method, what you should return to the caller? Mike is right, in Java generic methods only work with type parameters so inside the method you know what need to be returned from the type of input parameter(s). Marian Edu Acorn IT www.acorn-it.com www.akera.io +40 740 036 212
