B
bbrennan
What hardware and middleware are you using. As suggested, if this is still an open issue, I would recommend you consider Vocollect Voice by Honeywell. Paired with Honeywell mobile computers, it provides a very performant and rugged solution. I will also second the idea of having voice quality wireless coverage in very corner of the facility. Make sure to have a post installation survey completed that details universal coverage. This is not using your iPhone to walk around and look at bar strength. Find a vendor equipped with products like Air Magnet or Ekahau that will document the coverages, speeds and noise in the environment. Depending on where you are located, we might have some contacts for your consideration. Brian Preece at Ypsilon ( http://www.ypsilonsoftware.co.uk ) would also be a resource to contact. He and I have discussed his success in this area a number of times over the years. Bob Brennan Integrated Manufacturing Systems, Inc.
