[progress Communities] [progress Openedge Abl] Forum Post: Re: Virtual Memory Issue While...
  • Thread starter Thread starter Laura Stern
L
Laura Stern
When you call something asynchronously, the performance of the client side caller should not be affected at all by what the asynchronous call is doing. I presume when you say "I checked resource utilization of that main process, It is showing constant increase in virtual memory", I presumed you are talking about the server process. But then you say you suspect the async-request-handle which is on the client side. This is a tiny amount of memory and you get one handle per call. Yes, you should be deleting it when the request completes, but I doubt that you would see a spike in memory from this in any case, unless you were making thousands of calls. What is the client side doing while the async routine is running on the server?
