gus
one thing to be aware of: unless you have noatime mount option, a read is really a read data + write metadata (inode, etc). this has unpleasant side effects on some operating systems. don¹t recall when but there were versions of HP-UX that had a bottleneck on that. that could have something to do with your issue, or not. also: fork()'ing new processes is a relatively expensive system call that hammers the o/s virtual memory system. still, all of the above is just idle speculating too. regards, gus 3 Logicians walk into a bar. The bartender asks if they'd all like a beer. The first logician says "I don't know². The second says "I don¹t know². Then the third exclaims "Yes! On 7/5/16, 9:55 AM, "George Potemkin" wrote: >Update from Progress Community [https://community.progress.com/] > >George Potemkin [https://community.progress.com/members/georgep12] > >DimitriG4, > >> My feeling is that the "rm" being executed might not be the "out of the >>box" "rm". > >I never saw such things but your guess may be right: >rm is a tracked alias for /usr/bin/rm > >> still strange since the files are small, and why a different number of >>processes every time? > >Really the sript is dbmon.sh: >community.progress.com/.../25700 >[https://community.progress.com/community_groups/openedge_rdbms/f/18/t/257 >00] > >The script was used for all (10) databases running on the system. >By default dbmon is starting 3 promon sessions and one 4G session for >each database. In other words, it has started 40 processes. >All processes were started inside 3 sec interval - from 14:05:08 to >14:05:11 (though the script is trying to start them simultaneously). >Then dbmon has deleted the list of databases to monitor and the result >was: > >time rm $DbList2 > >real 0m12.56s >user 0m0.57s >sys 0m4.65s > >Then dbmon.sh has started vmstat and iostat. Both commands have started >instantly. > >vmstat 4 6 > >2016/07/05 14:05:24 procs memory >page faults cpu >2016/07/05 14:05:24 r b w avm free re at pi >po fr de sr in sy cs us sy id >2016/07/05 14:05:24 19 4 0 11644791 736268 3 0 14 >1559 0 0 10 33642 86662 11038 18 7 76 >2016/07/05 14:05:28 19 4 0 11644791 734051 0 0 21 >311 0 0 0 13606 601601 22498 38 54 8 >2016/07/05 14:05:32 19 3 0 11562973 758078 0 0 12 >328 0 0 0 14214 594769 23221 37 55 8 >2016/07/05 14:05:36 19 3 0 11562973 782987 0 0 6 >319 0 0 0 12863 542690 22198 33 51 16 >2016/07/05 14:05:40 19 3 0 11562973 794595 0 0 10 >266 0 0 0 9009 497981 11478 35 20 45 >2016/07/05 14:05:44 3 4 0 11521635 792468 0 0 3 >247 0 0 0 6715 220381 6276 26 6 67 > >Progress processes started by dbmon caused a rather large increase of >system time (time spent running kernel code). IMHO, it's not typical for >Progress processes. Due to the delay caused by the 'rm' command the >vmstat started and finished by 13 seconds after Progress processes. And >we can see that the system time returned to a normal value when Progress >processes terminated. > >The same customer, the identical Itanium box, the same dbmon script but >the result is different: > >2016/06/23 10:23:26 procs memory >page faults cpu >2016/06/23 10:23:26 r b w avm free re at pi >po fr de sr in sy cs us sy id >2016/06/23 10:23:26 1 0 0 1487739 3634458 0 0 2 >14 0 0 0 1257 924006 843 17 1 82 >2016/06/23 10:23:30 1 0 0 1487739 3631967 0 0 65 > 0 0 0 0 1505 85419 1473 8 4 89 >2016/06/23 10:23:34 1 0 0 1487739 3631985 0 0 36 > 0 0 0 0 1311 47381 1111 7 1 92 >2016/06/23 10:23:38 1 0 0 1497610 3631646 0 0 24 > 0 0 0 0 1231 31851 982 6 2 92 >2016/06/23 10:23:42 1 0 0 1497610 3631646 0 0 16 > 0 0 0 0 1218 22970 938 7 1 91 >2016/06/23 10:23:46 2 0 0 1501899 3631564 0 0 16 > 0 0 0 0 1239 21148 982 7 2 92 > >iostat 4 6 on the first server: > >2016/07/05 14:05:24 device bps sps msps >2016/07/05 14:05:24 > >2016/07/05 14:05:28 disk64 43 4.0 1.0 >2016/07/05 14:05:28 disk33 0 0.0 1.0 >2016/07/05 14:05:28 disk42 677 5.8 1.0 >2016/07/05 14:05:28 disk72 319 44.5 1.0 >2016/07/05 14:05:28 disk75 5 1.2 1.0 >2016/07/05 14:05:28 disk78 0 0.0 1.0 >2016/07/05 14:05:28 disk81 0 0.0 1.0 >2016/07/05 14:05:28 disk84 2 0.2 1.0 >2016/07/05 14:05:28 disk87 753 25.9 1.0 >2016/07/05 14:05:28 disk90 0 0.0 1.0 >2016/07/05 14:05:28 disk93 0 0.0 1.0 >2016/07/05 14:05:28 disk94 0 0.0 1.0 >2016/07/05 14:05:28 disk95 0 0.0 1.0 >2016/07/05 14:05:28 disk96 633 135.0 1.0 >2016/07/05 14:05:28 disk97 0 0.0 1.0 >2016/07/05 14:05:28 disk98 4556 290.7 1.0 >2016/07/05 14:05:28 disk99 0 0.0 1.0 >2016/07/05 14:05:28 disk102 0 0.0 1.0 >2016/07/05 14:05:28 disk107 1097 78.3 1.0 >2016/07/05 14:05:28 disk108 17800 391.8 1.0 >2016/07/05 14:05:28 disk113 103 11.2 1.0 >2016/07/05 14:05:28 disk114 254 31.7 1.0 > >One database on this server reads a lot from disk: > >07/05/16 Activity: Summary >14:05:12 07/05/16 14:05 to 07/05/16 14:05 (4 sec) >Event Total Per Sec |Event Total Per >Sec >Commits 33 8.2 |DB Reads 17263 >4315.8 >Undos 0 0.0 |DB Writes 14 >3.5 >Record Reads 307602 76900.5 |BI Reads 0 >0.0 >Record Updates 8 2.0 |BI Writes 3 >0.8 >Record Creates 8 2.0 |AI Writes 0 >0.0 >Record Deletes 0 0.0 |Checkpoints 0 >0.0 >Record Locks 89 22.2 |Flushed at chkpt 0 >0.0 >Record Waits 0 0.0 |Active trans 6 >Rec Lock Waits 0 % BI Buf Waits 0 % AI Buf Waits 0 % >Writes by APW 100 % Writes by BIW 33 % Writes by AIW 0 % >DB Size: 1771 GB BI Size: 20 GB AI Size: 0 K >Empty blocks: 455 Free blocks: 1860 RM chain: 83 >Buffer Hits 97 % Primary Hits 97 % Alternate Hits 0 % >4 Servers, 175 Users (126 Local, 49 Remote, 72 Batch), 2 Apws > >Summary: > >Discs are busy by the read operations. Starting 40 Progress processes >that are not resource consumimg (like promon) caused a significant >increase of CPU system time and caused a huge delay while using rm >command but reads/writes operations are not noticeably affected. I do not >still understand what is going wrong with this server. > >View online >[https://community.progress.com/community_groups/openedge_general/f/26/p/2 >5880/89171#89171] > >You received this notification because you subscribed to the forum. To >unsubscribe from only this thread, go here >[https://community.progress.com/community_groups/openedge_general/f/26/t/2 >5880/mute]. > >Flag >[https://community.progress.com/community_groups/openedge_general/f/26/p/2 >5880/89171?AbuseContentId=130508be-d634-4cf3-af41-b3f8cff5c2bc&AbuseConten >tTypeId=f586769b-0822-468a-b7f3-a94d480ed9b0&AbuseFlag=true] this post as >spam/abuse.
