[progress Communities] [progress Openedge Abl] Forum Post: Re: Temp Files Not Removed From...
  • Thread starter Thread starter Bill Wood
B
Bill Wood
With respect to this comment (from early in the thread) >>> Even I am not able to move these files anywhere if the files cannot be deleted of moved, then they may are likely still in use by an OpenEdge process. You may think your session has ended but there might be some process or service still running that is locking these files. If you cannot remove the files, check your Task Manager .... look for any Progress (_pro*, _mpro*, etc) executables. Other than that earlier replies have commented on reasons files might be left (broken process) and solution (-T) to isolating these files.
