[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: SYSTEM ERROR: I/O error 2 while compiling code
F
frank.meulblok
> I should also point out that it is possible that the class (gen\Common\NewVersion\VersionMigration) is being simultaneously compiled and saved to disk by a worker in a different _progres process. I suspect that's actually the cause of this - the session failing because it finds the partial .r file the other worker is writing to. Should be avoidable if each worker uses the SAVE INTO option to write the r-code to it's own folder outside of the propath, and merging the outputs of the different workers into a final set when they've completed.
