Akshay Guleria
Yes you can do that using the Split method of Regular Expression. Example code below: USING System.Text.RegularExpressions.Regex. DEFINE VARIABLE cSearch AS CHARACTER INIT "cProductNumer = '123' AND cProductName BEGINS 'PEN'" FORMAT "x(60)". DEFINE VARIABLE oRegExp AS CLASS Regex NO-UNDO. DEF VAR liLoop AS INT NO-UNDO. DEF VAR cResult AS CHAR NO-UNDO EXTENT. oRegExp = NEW RegEx("AND"). cResult = oRegExp:Split(cSearch). REPEAT liLoop = 1 TO EXTENT(cResult): DISP TRIM(cResult[liLoop]) FORMAT "x(60)". END.
