[progress Communities] [progress Openedge Abl] Forum Post: Re: Sort Order Of Identical...
  • Thread starter Thread starter Rob Fitzpatrick
Rob Fitzpatrick
To clarify what I just said, there are acceptable uses for ROWIDs. For example if you have a record in a buffer and you want to soon thereafter fetch that record into a second named buffer for that table, then you can FIND btable WHERE ROWID( btable ) = v-rowid. That's fine, it's a short-term use. But storing a ROWID for any length of time and depending on it to be consistent is risky.
