W
Wim
Dear Santosh, Thank you very much for your quick response and suggested approaches. Very helpfull, we wil certainly try this. Maybe one question: Will the other triggers for that object be left alone with this appoach? Regards, Wim Van: Santosh Patel [mailto:bounce-sapatel@community.progress.com] Verzonden: zaterdag 16 juli 2016 08:34 Aan: TU.Rollbase@community.progress.com Onderwerp: RE: [Technical Users - Rollbase] Running trigger on selected records possible? Desperate RollBase user needs help on this topic Update from Progress Community Santosh Patel When you select a bunch of records in a list view, this records selection is available on serverside (in triggers) using rbv_api.getSelectedIds() api. Can you model your trigger to be an object script trigger? If yes, you can use this api to get the IDs of all those records selected and then perform the action on all of them. documentation.progress.com/.../index.html An alternative is to create a workflow action of type "Run Triggers" (select your single trigger here), enable it to be executed for a group of records. This action will then be listed under more actions button on the list page. Select the records you want to execute it for and fire away. View online You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here . Flag this post as spam/abuse.
