[progress Communities] [progress Openedge Abl] Forum Post: Re: Run Triggers As A Specific...
  • Thread starter Thread starter Mani Kumar
Mani Kumar
Yes Wim your assumption is absolutely correct. Trigger used to update field --> Field Updated --> related trigger run because the field is updated - This is how it will and should be working. This option to select/not select triggers is an just an option/utility to ease when someone want's to run multiple triggers at a time instead of running one at a time. Do you have any specific reason or test case on why you don't want to run related triggers? Regards, Mani.
