[progress Communities] [progress Openedge Abl] Forum Post: Re: Remote Connect To Access Db...
  • Thread starter Thread starter pauldownie
P
pauldownie
In my case the physical name is different from the DSN but the physical name is not displayed in the Edit Connection dialog. The only thing I changed was the logical name to match the DSN. if you're saying that the -ld parameter just has to match the logical name defined in the SH I don't think that was my experience. I don't believe I was even using the -ld parameter as it wasn't in the connection string you posted. Or maybe that was the problem. Maybe if the -ld parameter is not included and the logical name is different than the DSN it will raise an error. Although I thought I had been including that parameter in previous tests.
